-   -   What's the Best Method of Removing Old Registration #'s from Hull? (https://www.offshoreonly.com/forums/general-boating-discussion/286153-whats-best-method-removing-old-registration-s-hull.html)
GKeats 10-09-2012 06:49 PM
Originally Posted by Too Stroked (Post 3793037)
If the numbers are self adhesive and the hull is straight gelcoat, heat them up with a hair drier and peel them off. Any remaining adhesive can be removed with Acetone. If the hull is painted, you can still use the hair drier, but use citrus cleaner to remove the adhesive.
If the numbers are painted on, use Easy Off Oven Cleaner.
What he said^^
lucky strike 10-09-2012 06:50 PM
Originally Posted by Scabby Jack (Post 3793029)
I've got some options now...4 posts with 4 different techniques to try.
Another...... Wet sand & buff :thankyouthankyou:
BBCLiberator 10-09-2012 10:32 PM
As already said, heat and peel, then acetone and you should be good to go. if they have been on a long time a good polish helps get rid of the shadow where there were in the gel.
Acetone is my wonder product, rub marks etc. Clean and wax afterward though.
mptrimshop 10-10-2012 12:23 AM
eraser wheel...it can be used on gel or paint..... If it is faded around the numbers wet sand and buff and pray it gets it all out...what ever you do don't sit on your boat and drink and look at it from all angles... Cuz u will prob always see it a little bit.
glenncal1 10-10-2012 11:34 AM
Originally Posted by mptrimshop (Post 3793325)
...what ever you do don't sit on your boat and drink and look at it from all angles....
Sitting on the boat and drinking is what I do the best....
:lolhit:
Quinlan 10-10-2012 05:22 PM
Take it to Vincents and Repaint Boat!
You cant go wrong.
grads2112 10-10-2012 06:19 PM
If the numbers are painted on and the boat is not painted, Easy Off oven cleaner works the best. I know it sounds strange and I thought it was crazy the first time I heard about it but it works great. Took me all of about 15 minutes to remove mine earlier this year.
Scabby Jack 10-10-2012 07:06 PM
They are vinyl so it shouldn't be too bad. Heat, scrape, acetone, then apply the new ones.
