winterizing
Old 10-14-2012 | 03:28 PM
Originally Posted by looseconnection
Do you warm up first to get stats open? Ihave always ran motors up to temp first to ensure all cooling passages are full of a/f.
YES ON THE HOSE THEN SWITCH TO THE BUCKET OF A/F.
A/F IS CHEAPER THAN A CRACKED BLOCK OR COOLER
JETTDOGG is offline
Old 10-14-2012 | 05:56 PM
Too Stroked's Avatar
Originally Posted by HEDGEHOGER
went to winterize the boat this morning and couldnt find the holes in the bottom of the block so i just drained the hoses and refilled the block with antifreeze through the hoses now im just hopeing the blocks full guess we'll find out in the spring
+ 3 (or 4) on this leading to a very bad experience in the spring. (Seen it waaay too many times each spring.) You must find both block drains (on the sides of each block), pull the plugs, then rod out the hole with a piece of wire, a zip tie or something else to dislodge any sediment. Also, did you pull the lower hose on the circulating pump on the front of the motors or just the hoses leading to the exhaust manifolds? Did you drain the power steering cooler?
Too Stroked is offline
Old 10-14-2012 | 07:05 PM
masi242's Avatar
Hey guys I have been winterizing for many years, but never drained the block. I always run the engine to temp and ran anti-freeze with know problem. This year I did it different ran to temp and drained the block then did the anti-freeze, but I only got three gallons thru before the engine started to heat up it was coming out the exhaust at that point, so I shut it down. Then drained the exhaust manifold. Question is that enough anti-freeze
thanks
masi242 is offline
Old 10-14-2012 | 07:47 PM
Where is this power steering cooler? What is the steering system? I am concerned about all freezing aspects. What does one do about the 'select' exhaust system?
wwahl is offline
Old 10-14-2012 | 07:57 PM
Default fixx
thanks
what happens is the thermostat will snap shut before it has a chance to move the antifreeze through the block then you just fill the exhaust manifolds and risers and thats why it takes less antifreeze.. i always use a bilge pump and a tank to winterize all the boats i do..
[YOUTUBE]http://www.youtube.com/watch?v=LzDob8um5Xc[/YOUTUBE] i also fog the engine when its running..
FIXX is offline
Old 10-14-2012 | 08:03 PM
masi242's Avatar
Should I pull the t-stat and fill extra just to make sure
masi242 is offline
Old 10-14-2012 | 09:04 PM
We usually pull all the drain plugs...run the engine for 10 seconds burping the throttles to get most of the water. Then we run a/f thru muffs on a pump for 3-4 mins, ensuring the t stat is open.
in your case if you can't start the engine...pull all the plugs and fill with a/f. you won't have a problem. On our 6.2's there are 3 but the most important one is the main plug on the bottom in the front. not sure about your setup.
1MOSES1 is offline
Old 10-14-2012 | 09:14 PM
masi242's Avatar
Thanks I think Fix has it right the water was hot coming out off the block, but by the time i had anti-freeze going thru was a few minutes later 5-10. So I guess the T-stat was closing, I`ll pull the T-stat an add a little extra.
masi242 is offline
Old 10-15-2012 | 05:52 AM
Originally Posted by JETTDOGG
I took a 5 gal screwed a outdoor hose into the bottom- side attatched a legnth of garden hose to the spicket and my water ears on the drive.
Put a few gallons of anti-freeze in the bucket and set it higher than the drive.
Start engine open spicket and fast idle until i see only anti freeze coming out the exhaust.
Leaves pure a/f in engine.
Best part is no screwin w/hose clamps, etc. And you can use it year after year
if your thermostat isn't open, you get a/f out the exhaust and block is still full of ocean or river water.
dereknkathy is offline
Old 10-15-2012 | 06:02 AM
also, you need hot water to open a t-stat. drain an engine and start it and the thermo will close. the hot steamy air in the cooling system at that point doesn't open thermostats. if you can't run engine, take off water pump or crossover. drains motor pretty far down. reinstall and fill with straight-not 50-50- real antifreeze-not pink RV crap. remove t-stat housing and fill thru there. then hold hoses that feed exhaust down below bottom of exhausts. and put drives down and leave them there all winter. your shift boots and trim cyls will thank you in the spring...
