Cummins 6BTA 5.9 Performance Build
#82
Been there, this is a result of about 9000 rpm after some driveline broke:
http://s624.beta.photobucket.com/use..._1859.jpg.html
#83
You got one thing right and that was that the head studs held. He didn't touch the wastegates and it happened at 80 lbs of boost not 160.
#85
The owner didn't excited make any adjustments to the wastegates, and when the engine let go it was at 80 lbs of boost not 160. I don't claim to be Kurt Haisley but there is no way that a stock 6bt block could handle that much boost. A woodruff billet block would hold up to some serious boost but don't think the head studs would hold at 160lbs.
What I'm saying is your information is false.
#86
Here you go
#87
Here is the old 7.3 powerstroke it had a big turbo.
http://www.youtube.com/watch?v=oTMj8...7&feature=plcp
#88
That stock block (no cement) let go at 80 lbs of boost while also at 6k rpm. It was making 1200+ hp and over 1700 ft lbs and climbing. I know that a stock unmolested block can handle 100+ lbs of boost, but not 160 lbs of boost. If as you stated back pressure is under control.
#89
#90
