Toluene
i HAVE USED LUCAS OCTAINE BOOST THIS PAST SEASON AND STOPPED USING IT BECAUSE ONCE AGAIN I THOUGHT IT WAS POINTLESS(LIKE FEEDING A TIC TAC TO A WHALE)
SO YOU ARE SAYING LUCAS WILL INFACT BOOST OCTAINE ENOUGH TO MAKE A DIFFERENCE?(SAY A COUPLE NUMBERS) I USE 91 OCTAINE (NON ETHONAL) AND EITHER USE C-12 OR LUCAS TO INCREASE MY OCTANE RATING TO 96 IN A 100 GALLON TANK. DO YOU HAVE ANY MORE INFORMATION REGARDING THE LUCAS TO BE ABLE TO INCREASE OCTAINE BY NUMBERS AND NOT POINTS?
When you refer to 100:1 does that mean 1 bottle of boost per 100 gallons? If you could explain that part i would appreciate it. I am lost on the ratio parts. Also by 3.5 points you are referring to actual increase in the number in octane,not points correct? Nos has a boost out that claims 60 points and 6 numbers in octane. Can that be true? Or is lucas the leading competitor in the market. I got big cubic inches at 10:1 compression. Not really a high compression motor, just want some safety zone there when i lean on the sticks. With the deteriorating quality of pump gas i would like to be safe by having some more octane then just relying on a stations pump gas.
when the 110 octane I was buying for a few years went from $2.92 a gallon to over $6 per gallon in one week I started doing some research on having race fuel made and marketed. Most of the cheeper brand race fuels are 87 or lower octane offroad fuel with toluene and a little hydraulic oil mixed together. The toluene evaporating is why they loose octane over time so fast.
Turbo blue 110 octane is 51.7 gallons of 87 octane and 2 gallons of toulene and .3 gallons of hydraulic oil.
Sunoco high end fuel is the only race fuel that is not made from low octane pump fuel as a base
We spent a lot of years researching and messing with the stuff trying to make HP in very small engines. (Getting it past tech/fuel tests is a challenge.) It is very dangerous for a number of reasons as stated, and in the volume you guys are discussing, my advice is to buy race gas and beer and be healthy and happy.
Give Torco a try. I heard this is the best product for increasing octane. It's a fuel concentrate, not an octane booster.
http://torcoracefuel.net/pro-accelerator.html
