View Poll Results: Bravo XR drive breakage
Broke upper gear set
71
82.56%
Broke lower gear set
15
17.44%
Voters: 86. You may not vote on this poll
Old 08-11-2023, 01:22 PM
  #91
F-2 Speedy's Avatar
Received 3,052 Likes on 1,357 Posts
Im running way more than 600 a side with XR's and IMCO bottoms, zinged the props a few times at the Cig event on LOTO and held up so far......... TPB all depends on the budget, I dont think you need to go over kill with 600 hp, you could drop 15k + for a Imco SCX but dont think you need to.
F-2 Speedy is offline
Old 08-11-2023, 03:19 PM
  #92
Received 1,329 Likes on 742 Posts
Originally Posted by TexomaPowerboater
So after reading this thread sounds like everything junk except a #6 drive? That can't be right. What kind of outdrive is best bang for buck for something in the 600hp range or less?
My personal opinion that means nothing, a XZ drive. Since they do not make the whole drive I think I said it on here before. When a friends 525 powered XR drive started to pit the gears he bought XZ gears, had them cryno treated and put in. I think he had 100 hours on it and every time he changed gear lube the plug was clean.
The guy has the boat in Chi town area now, think he may be at LOTO for the shootout. Its a 2007 35 single step fountain with a 18.5" X,,,,,,,, running 5 blades with diffuser rings so it will get on plane.
Wildman_grafix is offline
105Fountain (08-13-2023)
Old 08-12-2023, 09:40 AM
  #93
253
As far as broken gears go,,I see many more broken XR Upper gearset's come into my repair shop than any other Bravo outdrive
253 is offline
Old 08-12-2023, 03:37 PM
  #94
fountain4play's Avatar
Originally Posted by Smitty
Taking a survey as to what you have personally had happen to your XR drive if it broke.
I need to know what failed first, not the other parts it took out in the process.
I am working on an improved upper gear set and also think the lowers are an issue for some as well.
Thx
None, swapped mine out for Arneson's years ago.
fountain4play is offline
Old 08-13-2023, 10:54 AM
  #95
Default Bmax
600hp on a 37 Talon 110 hours no issues
HuskerPerformance is offline
Old 08-13-2023, 12:33 PM
  #96
seems like a lot of the boaters on heres problems would go away if they did the same thing you did but everyone is stuck on the bravo or their derivitive at a great cost in both money and speed
Boatlesss is offline
