Polk MM691's VS ?
Old 12-29-2012 | 04:10 PM
Nightlife1970's Avatar
Originally Posted by jwurl
I put the 691s in my Fastech. Big improvement but they are still only 6x9s. You can easily get them to distort with just the power of the head unit. No need for an amp. Jeff Wurl
Not the speakers distorting, but the crap amp in the head unit. Get a good amp and really see what those speakers could do.
Nightlife1970 is offline
Old 12-29-2012 | 04:17 PM
Originally Posted by looseconnection
Look like I will be doing jbl 6004 amp with 2 or 4 691's. I have a huge list of projects this winter and don't want to rush install of two more 6x9's. May use 6.5's instead of 6x9 under rear bench but am I loosing much doing this?
I would not put any speakers in the rear bench unless they are subs. Putting 6x9 or 6.5's down there is a waste. Unless you are going to be laying on the floor to listen to them. Put mid/Hi speakers up as high as you can so you can hear them. Put subs close to the floor to get half space gain off the floor.
If you already have 6x9's in the bench, take them out replace them with some 10" subs. Move the 6x9's up higher, and you will make a vast improvement in sound.
Old 12-29-2012 | 04:22 PM
You could run all four 6x9's with two channels of that amp. Then use the other 2 bridged to run a sub.
Old 12-29-2012 | 06:48 PM
do tell me how.
series or parallel?
I assume parallel.
looseconnection is offline
Old 12-29-2012 | 11:55 PM
LubeJobs42's Avatar
I just put 4 sets of MM651's in the MTI i just bought to screw around with. I heard them today for the first time and they really sound great. I think i need to change to larger amps as the cones were bearly moving.
LubeJobs42 is offline
Old 12-30-2012 | 09:23 AM
do tell me how.
series or parallel?
I assume parallel.
Yes you could run one half of the amp in stereo for your 6x9's. Running them in parallel. Then bridge the other two channels to run a sub.
Would not be perfect power for the 6x9's, but still better than the headunit amp.
Would be alot better system than runing four 6x9's off the HU with two of them in the bench. Might as well get you some maximus speakers from the 80's and a Kraco HU for that setup.
Old 12-30-2012 | 12:54 PM
Are the db691's rust proof? May do 4 and a 4 channel amp. But how much rms watts per channel is needed. I think they are rated 100rms and 300peak. So will a 4channel amp with 50 watts rms do fine or will it need to be closer to 100 watts rms.
Yes, they are for marine use. Check out Polk's website, or talk to their tech line. I say more power and quality amp=cleaner sound. You'll be amazed how your system will sound with a good amp and speakers. Without an amp, it's going to clip. Picture this, on the water enjoying the day, maybe having a few and you wanta hear your favorite tune. LOUD Not going to happen in an open cockpit boat, all you'll hear is distortion. You can get away without an amp in a car, not in a boat.
Lots of good stuff on the market.Unless you're one of the lucky people from the deep south, you have all winter to shop.
BC
Cold Sweat is offline
Old 12-30-2012 | 01:10 PM
Just to give you and idea what size amp you can use, the MM,DXi, and db series Polk 6x9 speakers are rated @ 125 watts continuous, 300 watts peak.
Old 12-30-2012 | 02:40 PM
Thanks guys!
LC
Old 12-31-2012 | 11:08 AM
I'm considering upgrading my stereo this winter as well. Stumbled on these speaker grills that look like will work with the Polk MM691's. A little plain looking, but they offer more protection and will blend better in a mostly white interior.
It is model number DXI69 MG and Best Buy carries them.
4mulafastech is offline
