At what point you need to upgrade exhaust?? >
Old 01-22-2013 | 10:36 AM
Default At what point you need to upgrade exhaust??
I'm kinda confused with when you need to upgrade your exhaust system...
When you go up in HP from the stock 260-300hp to say 350-400hp... do you need to get performance exhaust? I DO NOT want to upgrade/spent 1,500.00 if I really dont have too on some stainless marine exhaust...Ive herd you really dont even see a performance change when putting on the performance exhaust on.
Jackdonz is offline
Old 01-22-2013 | 11:04 AM
Knot 4 Me's Avatar
Your cam selection will more determine your need to change to a different manifold/riser setup than a HP number. Merc's 350HP Scorpion small blocks came with the standard cast iron manifolds/risers.
Knot 4 Me is offline
Old 01-22-2013 | 11:07 AM
at that power level, you should be good with stock or aftermarket manifolds and good risers with a 4 inch through hull exhaust. for headers to be worth while you would need to be at a much higher power level. high dollar exhaust sure does look nice and pretty though!
sr73z is offline
Old 01-22-2013 | 11:33 AM
LOL, yes... i know they sure do look good... so if i do hit the 400hp then ill just do the HGE aluminum stock replacement Manifolds... 229.00 each sounds good to me. Saves 100lbs.
http://bpi.ebasicpower.com/pc/HGE7114ALUM/MPMANIFOLDS
Jackdonz is offline
Old 01-22-2013 | 11:56 AM
You will want to upgrade when you need new manifolds or you want to spend a bunch of money for little to no gain.
VetteLT193 is offline
Old 01-22-2013 | 12:10 PM
LOL spend a bunch of money for what?!?! Oh yeah... Bling Bling!!
Jackdonz is offline
Old 01-22-2013 | 12:37 PM
I heard you pu 1 to 3 mph from weight loss and improved flow
Delforce22 is offline
Old 01-22-2013 | 12:56 PM
You'll get gains if the boat is really weight sensitive and/or your old exhaust is falling apart.
You might get some gains from more power if you are on the higher end / cammed up.
My brother did really good with a new exhaust on his old 22 Donzi, he picked up a couple hundred RPM when he went to CMI if memory serves. That was a Big Block though and I think they respond better to the exhaust. SB with the 4 inch exhaust already flows quite well for the engine.
On my old boat I did exhaust but I also did a new carb, fuel pump, among other things. I picked up a bunch of RPM... the old exhaust was rusted out junk so I don't know exactly where it all came from.
Old 01-22-2013 | 01:35 PM
Yeah... with the 4 inch IMCO stainless risers i have and some new aluminum HGE manifolds will be fine for the time being... like i said... Im going for 350-400 hp... thats it. I dont want to be hurting my alpha SS...
Jackdonz is offline
Old 01-23-2013 | 09:53 AM
TomZ's Avatar
I did the same with the 383 that was in my old boat, but I also had the risers extended to the transom tips (BIG roller cam... for a marine small block away). I had less than a grand in the whole exhaust system, and it supported close to 500 HP.
I'm now using Merc/Gil (496) manifolds on my 454 Mag.
TomZ is offline
