Custom Engine Builders
Old 02-20-2013 | 11:07 PM
  #71
Originally Posted by only1adrian
lsx with twin turbo's 6lbs of boost.
Nevermind, I cant get pic to post.
Anymore specs on this build?
cheech is offline
Old 02-21-2013 | 09:10 AM
  #72
Great informative thread. Thanks to everyone for contributing and not crapping all over one another in the process!
bulletbob is offline
Old 02-21-2013 | 12:59 PM
  #73
Originally Posted by professor_speed
Imo The LS will shine in up some 30 foot singles and Maybe up a to 38 in twins. Beyond that to make a single speed transmission set up work you really need more torque. Two speed marine transmissions are too rpm limited cause they were designed around diesels, Now if you turbo them, I think you can stick with a bbc to 1200 hp. (1000hp is probably more realistic though) Past that You are going to need an aftermarket LS block and 6 bolt heads other wise, you will lift the heads in a boat environment, And the turbos are going to get too big to bring in boost fast enough to make the torque down low that's needed(you can get away with more for short
I've been contemplating this transmission idea. I wonder if it be possible to repurpose a powerglide and remove the TC to make it direct.
I don't generally like the idea of forced induction LSX's due to their lack of head bolts, but maybe that theory has been debunked.
hogie roll is offline
Old 02-21-2013 | 01:31 PM
  #74
Yes a glide can be set up direct drive and the parts are off shelf stock car stuff, also it can be built as a shorty and would be about the same length as a BW72c but, there are no decent ratios. first gear is too low, reverse is two low as well. LS four bolts will hold fine up to an easy 800hp. There are ways to go way further than that if needed. studs Help, some aftermarket head castings are thicker which is really the problem. (All the GM castings are thin)
professor_speed is offline
Old 02-21-2013 | 01:36 PM
  #75
Its not a problem with the Real LSX brand block However they are pricey!!
only1adrian is offline
Old 02-21-2013 | 01:53 PM
  #76
I will see if I can find the build sheet around here and let you know.
Old 02-21-2013 | 03:55 PM
  #77
I was running around 14psi through a whipple blower on my totally stock LQ4 for around 30-40k miles with zero problems before changed my setup. I've seen plenty of FI setups on the LS motors and haven't heard of any real head lifting problems.
My current engine with the actual "LSX" block has additional head bolts and extra cooling features.
Bromaguire is offline
Old 02-21-2013 | 08:19 PM
  #78
This was part of testing with this motor, We actually detuned the motor to only about 930hp due to the heads lifting. It is a big problem, but again, if your gonna spend that money, might as well get the LSX block.
Old 02-21-2013 | 08:28 PM
  #79
Ok, I wasn't running 1000hp on my completely stock motor but closer to 650-700hp and there were zero problems. I'd agree if you plan on going for anywhere near 1000hp an LSX block is a better choice, although there are people pushing the non-LSX block that far.
This quad turbo motor built by my engine builder was making over 1600hp at 6psi and had no head lift problems with the LSX block.
Old 02-21-2013 | 09:04 PM
  #80
Thats some nice Hardware!!!!
http://www.shutterfly.com/lightbox/v...cd1d30d33b21f1
