Victory Reportedly Withdraws from Class 1
#41
maybe someone could give the history of the 3 main surfaces drives, atleast the ones i know of :
1 arneson
2 bpm
3 ZF
#42
arneson-industries.com
Offshoreonly Advertiser
The BPM is a licensed copy of the Arneson ASD8. Every BPM uses our stock ASD8 parts that we supply. Buy either, we make the parts for them. We also make a rudder, fixed trim cylinder, and drive unit that is like the BPM units. Steerable or fixed either way. Latham, MTI and others make a rudder also.
Arneson Surface Drives www.arneson-industries.com
#43
Trimax (and Ring) drives are a collaboration between Buzzi and ZF.
The Trimax is non-trimable bare shaft with water-lubed cutlass bearings (there are ways to make it auto-trim a ½" or so), designed to be installed under a bustle, and includes a blow-tube and tiller-per-wheel.
All of Buzzi's installs have a raw-water pickup on the trailing edge of the rudder, but that is special order from ZF.
#44
isn't the bpm an italian company ?
does the arneson still use a chain drive in the drop bos on the oneside ?
#45
Some drop box Arnesons use chain, some use gears, some have neither. All work within the parameters of their ratings.
#46
I would imagine that any patents on sleeved shafts and associated bits have long expired, and are replaced by licensing and manufacturing agreements.
I have no idea if you can get an ASD8 non-gimbaled, but I'd wager you can ... shazam ... it's a BPM or a Metamarine.
#47
Exactly, and yes BPM is Italian. We are a global company and do business virtually everywhere. Dave you have seen a BPM right. It's not a far stretch to see that it's an Arneson. The drop box looks 80% like an original 1600 drive unit even.
has a shaft.
just wondering how this played out, are you saying bpm never had their own drive and was always under arneson global company ?
as for the bpm it seems to me to be a more race version of the arneson, developed for rudder only and vertically trimable. and for the drop boxes, i was under the impression that the bpm's are all gear driven and the next step in evolution was SCS's quick change gear box that alot of the class one guys use.
i'm only referring to race applications or high performance here.
#48
Pretty informative summary of ZF offerings, incl the Trimax, ZF's "arnesons" (incl BEEG ones) and their fly-by wire.
http://www.zf.com/media/media/docume...ad_2008_03.pdf
#49
i've seen both up close and NO i don't see how it's an arneson or copy of ? other than it
has a shaft.
has a shaft.
The majority, 90%, of the Class 1 guys use the Victory drop box.
