Help, lost a motor, electrical, not mechanical >
Old 07-21-2002 | 09:55 PM
Default Help, lost a motor, electrical, not mechanical
Came into the harbor, port motor started to pop and lose power, shut it off and came in on one motor at 30 MPH on one motor,
On the lift, no power to the port motor, no low oil buzzer, not volts, not a thing. Checked the circuit breaker and the connector plug, no help. Where do I go from here? Batteries are new with 12 V showing. HELP
THANKS
Shawn
shawn is offline
Old 07-21-2002 | 09:57 PM
Waterfoul's Avatar
Gone Fishin'
does it click when you turn the key? Starter relay bad???? Solenoid??
Waterfoul is offline
Old 07-21-2002 | 10:19 PM
Smitty's Avatar
Default Check your kill engine kill switch
Check your kill switch--the one that the lanyard is attached to. If that is good double check connection at ignition switch.
Smitty is offline
Old 07-22-2002 | 02:10 AM
Since you're not getting any volt readings when turning the key to "on", I would check the wiring at/to the starter. I've had this happen to race cars before and it was caused by a hot wire chafing and grounding out. Had the exact same symptoms of running rough. I would bet that the hot wire is grounding out on the engine somewhere.
Griff is offline
Old 07-24-2002 | 12:48 PM
dyno's Avatar
Charter Member #655
I lost one motor monday and was like Bigwavz said the kill switch gave up hot wired across it and it started right up!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 07-24-2002 | 12:52 PM
Audiofn's Avatar
Charter Member #232
Yup check the kill switch before anything else. Then go from there.
Jon
Put your best foot forward!
Audiofn is offline
Old 07-24-2002 | 01:18 PM
Turns out I lost the 90 amp fusable link on the starter. Can't find the cause, it did not seem burnt blown or blackened. Can only guess its a mechanical failure and it simply broke. I am replacing it with a circuit breaker since I don't know the cause and at least this way, I can reset it and get on plane to get home if it ever happens again.
I got lucky when it failed Sunday, I was on plane and I could get back home still on plane with one motor. 30 mph IS a lot better than idling in at 6 mph. Any guess on cause will be appreciated, and thanks for the input.
Shawn
shawn is offline
Old 07-24-2002 | 01:29 PM
dyno's Avatar
Charter Member #655
anyone know where I can get a new Kill switch? EMI has them on there site but almost $50...... come on!!!
dyno is offline
Old 07-24-2002 | 02:03 PM
Smitty's Avatar
Try BOATUS.com or something like that. Or see if there is a West Marine store near you.
Dave
Smitty is offline
Old 07-24-2002 | 02:04 PM
283CHECK
Default Had the same thing happen lastyear
But it poped as soon as I shut the engine hatch after replacement. In my experience with cars and some with boats I have never seen a fuse just get old and fail(is it possible?) I'm willing to bet that you have a hot wire(full 12v)that has rubbed the insulation off and is touching metal(ground)some where. Mine was caused by the silent choice wire, it was being pinched between the hatch motor and oil cooler it finally wore through and poped the fuse. I'd say check all of your wires that either run over metal or could possibly be bounced into some metal all it takes is a quick touch!!
Good luck
Chris
Livorsi Marine
New Products and Member Discounts
1
09-05-2006 02:07 PM
tj309
2
11-09-2005 09:30 AM
East Coast B
18
06-04-2005 12:22 AM
bglz42
19
08-04-2004 06:25 AM
