4 5/8" hole saw for Tach/Speedo options?
you sure its 4 and 5/8ths? I just did a couple dashes and the Livorsi tach was a tight 4 1/2. Had to clean it up with a piece of 80 but 4 and 5/8ths would have been way to big.
08 OPA High Points Champion
This is the easiest and safest way to not mess anything up. 3/8 plywood is sufficient and will guard you against hitting anything else. Make sure you pull the pilot bit out and make sure you clamp it down good.
