LS vs Big Block
Old 04-11-2013 | 07:56 AM
  #151
Here is a 500 cu. in LSX
http://www.chevyhiperformance.com/te...d/viewall.html
wannabe is offline
Old 04-11-2013 | 08:52 PM
  #152
Originally Posted by spectras only
The stripes are at the waterline when the boat sits. The bow rises on take off and tabs help to level the boat. The boat is well balanced. There's a 100 gal ballast tank with pump in the bow to trim the boat in heavy seas that can be as high as 8 -10 feet crossing the Georgia Strait to his summer residence. My friend built the mold for the boat while he worked at Sovereign Yachts [ now Richmond Yachts ] here in BC. It's a one of hull, he destroyed the mold afterwards.
Under construction finishing rigging at his house
Helm
White gelcoat before painting the hullsides Boat has a swimgrid added since.
Rear entrance
I hope he never needs to pull the engine!
bert4332 is offline
Old 04-12-2013 | 12:57 AM
  #153
Talking
we put it in through the starboard hatch in 15 minutes using a crane of a flatbed truck. Guessing it wouldn't be much longer taking it out in reverse,LOL
spectras only is offline
Old 04-17-2013 | 09:08 AM
  #154
Im a huge LS fan but Its job is not to replace a BBC in a boat. It does make a BBC almost useless in a sub 550-600hp form. if you add a blower then 850hp becomes the number where I like a LS better. Imo an LS motors biggest asset has nothing to do with the engine it self it has to do with all the engineering that the general has done. IE economies of scale.
If you are going to build a "gee whiz" ls engine with aftermarket everything then dollar for dollar (and like induction types) a BBC is going to piss on your parade.
If you are going to use GM to your advantage then use GM parts. LS3 heads are dirt cheap and damn good.
LS valve trains are simple stable and reliable.
LS blocks are pretty cheap and stable until you way beyond the design parameters.
350-400hp = 5.3l stock except 21x, 21x cam, comp 918 springs, hardened push rods, ls6, fast or Holley mid ram intake or edlebrock duel pane for carb.
400-475hp = 6.0l stock except 22X-23X cam, patriot double valve springs hardened push rods, Fast,Victor Jr, pro-flo, Holley Mid or Hi ram intake.
475-525 = 6.2l (or 6.0l with square port heads) stock except 22x-24X cam push rods, double springs Fast, victor Jr,pro flo or Hi Ram intake.
Add a 4" stroke crank to any of the combos (Vs 3.622 stock) should be good for +50ish hp and TQ
LSA is 550hp stock I would put better springs and push rods in stock one.
Throw a 2.4" pulley and you add about 80hp! (best $150 bucks ever)
Throw a cam in and port the snout on the blower and you are at just a touch under 700hp
Throw TVS 2300 blower (vs TVS1900) and you can get 800hp
Oh yeah if you shop smart you just spent under 25k, Marinized, closed cooled, electronics and all. And if you need a little more remember that 4" crank set up.
I would have no problem spinning a LS 1000-1500 Rpm faster than a BBC. The valve train only needs springs, and push rods to be reliable, Its also way lighter that a BBC VT, The bottom end is super stable and rotating assembly is lighter than a BBC so even at higher speeds the stress is not higher.
I would run an accusump on any engine turning those speeds though. (assuming dry sump is not in the budget)
professor_speed is offline
Old 04-17-2013 | 12:08 PM
  #155
Texas Speed and performance will build you a fully blue printed 600hp 418 with forged internals, warrantied, custom ECM, etc for about 14K. Add headers for 5K and closed cooling for about 1K and your in less than 20K.
I think water thunder has a similar setup for 15K with closed cooling, but that includes their down turned headers. IDK what they'd refund you for leaving those off. May get it down to 13K.
The thing I like about the ls motors in the500-600hp range over bbc's is I think they'll be easier on bravo drives due to the torque kicking in later in the curve.
Tigeman is offline
Old 05-12-2013 | 02:58 PM
  #156
How about a V12 LS motor? 8.9 liter using stock stroke and bore.
http://www.motorauthority.com/news/1...some?fbfanpage
http://www.foxnews.com/leisure/2013/...chevrolet-v12/
http://ls1tech.com/forums/conversion...ls1-build.html
It's pretty expensive, but hey, it's only money, right?
Ernest T Bass is offline
Old 05-14-2013 | 02:38 PM
  #157
http://www.thomsonautomotive.com/youtube.html
700 hp, 780 ft. lb on 10 lbs boost.
Yeah, no low end torque in these motors.
wannabe is offline
