Paint question
Old 07-25-2002 | 09:44 AM
rv
Default Paint question
Could someone with painting experience help me with this.
I painted a small section on our trailer with PPG paint and activator. I would like to know how long to wait before wetsanding and buffing the ridge left behind from the masking tape.
Thanks,
Rick
rv is offline
Old 07-25-2002 | 10:04 AM
In the heat of summer I have sanded PPG paint the next day,....Fred
fred is offline
Old 07-25-2002 | 10:15 AM
rv
Thanks Fred,
I will have to move it out into the sun, sounds like it should be ready then.
Rick
rv is offline
Old 07-25-2002 | 11:03 AM
rv
TooOld,
It is a single stage paint, no clear coat.
I think the numbers are something like AU 100 and 101.
Rick
rv is offline
Old 07-25-2002 | 11:33 AM
Audiofn's Avatar
Charter Member #232
Next time you do this pull the tape when it is still real wet then the edge will blend in for you
Put your best foot forward!
Audiofn is offline
Old 07-25-2002 | 12:05 PM
rv
Thanks for the info and tip, guys. Next time I will try pulling the tape early.
Rick
rv is offline
Old 07-25-2002 | 02:47 PM
later's Avatar
actually next time mask off with paper rolled farther back feather the paint out in steps and then after the last coat take a hot reducer ad spray directly over the dry area to melt down the feather edge and walla your done and no sanding or polishing well maybe a little polishing and you wouldnt even see a mask line or a difference in color. unless the colors or terrible off in the first place. your eye cant pick up a gradule change in color as a straight tape line creates.
later is offline
jdinvt
09-09-2007 05:28 PM
sd11856g
Detailing, Painting, & Fiberglass
3
04-26-2007 08:13 PM
nickodemo
7
11-30-2006 12:22 PM
2112
7
03-11-2005 09:48 AM
THRILLSEEKER
03-30-2003 04:35 PM
