ultimate setup/garage thread >
Old 05-26-2013 | 09:35 PM
DirtyMoney's Avatar
Floor almost done. More cleaning then sealant. Total cost for 2400sqft around $1,000
Attached Thumbnails ultimate setup/garage thread-2013-05-26-19.47.56.jpg   ultimate setup/garage thread-2013-05-26-19.48.02.jpg   ultimate setup/garage thread-2013-05-26-19.48.08.jpg
DirtyMoney is offline
Old 05-26-2013 | 09:46 PM
Cash Bar's Avatar
Mod Squad Enforcer
Looks awesome DM. Nice job. I need 12 acres in N Ga I think.
www.gregsellswaterfront.com
Cash Bar is offline
Old 05-26-2013 | 09:55 PM
DirtyMoney's Avatar
Yes you do!
Old 05-27-2013 | 07:25 AM
Obviously anyone who keeps their boat in a garage takes good care of it, we all know what a pain in the azz it can be to vacuum. I sort of installed a central vac by running 2" PVC up the wall and across the ceiling, connect my shop vac to the PVC at the bottom and a 10' long vac hose at the top. It reaches everywhere. I also put a switch on the ceiling to turn the receptical the shop vac is plugged into. For $20 worth of pvc this was money well spent.
SPEEDFREEK is offline
Old 05-27-2013 | 02:50 PM
Originally Posted by precisiondetails
Would like to build a nice shop/garage on my property one day, what are the costs for some of these garages? Say 40x60 16 foot garage...?
48x72x15'6" pole building 28,000.00 installed, (4)14x14 doors 5000.00 installed, 8000.00 for concrete, rebar and wire fabric. Placed concrete and installed electrical myself.
RAPTOR1 is offline
Old 05-27-2013 | 02:56 PM
That floor looks great! Is that a slotted drain?
RAPTOR1 is offline
Old 05-27-2013 | 03:05 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Brilliant. I will be doing this soon. One large ladder hook hanging from the rafter, and a long hose to reach the cockpit and cabin; already planning it out.
Sydwayz is offline
Old 05-27-2013 | 03:40 PM
If you want a cheap, readily available long hose look for a pool vacuum hose like this: Pool Hoses And Pumps : Pool Supplies - Walmart.com
Only issue is old hoses will crumble if it has been exposed to sunlight/chemicals and they shouldn't kink when new but as they age they might kink under heavy suction. Most of the good ones are tight at both ends where the collar meets the hose but some are just screwed onto the hose.....nothing some silicon/glue couldn't fix.
Jupiter Sunsation is offline
Old 05-27-2013 | 04:21 PM
DirtyMoney's Avatar
Yes a self falling drain. You simply install the sections by number and they have built in fall.
Old 05-27-2013 | 07:21 PM
That's sweet, county regs. don't allow any floor drains here but I did slope the floor towards the middle in two bays so one may show up in time!!
RAPTOR1 is offline
