GPS location in dash
Old 05-25-2013 | 03:43 PM
Originally Posted by BGIII
What about something like this?
[IMG][/IMG]
I like that better except I would center the GPS on the dash panel and put a tach on either side so it looks symmetrical. Then move the speedo down to the center of the lower panel. You really don't need it up there because you can program the GPS to display speed overplayed on whatever screen you are using.
hotjava66 is offline
Old 05-25-2013 | 03:47 PM
Oh, and before you commit to that location pull the back side off the panel and make sure there's enough room on the INSIDE of that location to facilitate mounting there. I was going to do the same thing but my fairing was built pretty heavy and did not leave enough open space behind to do it.
Old 05-25-2013 | 04:49 PM
c_deezy's Avatar
Actually you could just get rid of the speedo altogether, you don't really need it with the GPS. Personally I would keep the tachs side by side, but put the GPS on the left hand side of the panel, tachs on the right. That way it is still accessible to you, but a passenger also has easier access to it.
c_deezy is offline
Old 05-26-2013 | 08:59 AM
mrpickett357's Avatar
Originally Posted by Zero Patience
I redid this dash and angled the 5208 for the owner
It's all about the angle. When ZP fabricated this one for me , it put the screen at the correct viewing angle for easy viewing and it's also very easy to see in sunlight.
mrpickett357 is offline
Old 05-26-2013 | 10:16 AM
scarab33rcng is offline
Old 05-27-2013 | 08:31 PM
Is it common to ditch the speedo these days when you have a built in GPS?
BGIII is offline
Old 05-27-2013 | 08:44 PM
Yes, no need for the speedo . The screen needs to be straight in front of you. If your looking at it on an angle you won't be able to read it in the sun at all.
jbraun2828 is online now
Old 05-28-2013 | 09:40 AM
That looks good. We have a 740 and really like it. If you mount if vertical you will be able to see it better in bright conditions. We have no problems with that on ours. Plus if you mount it there it is not a big eye shift (position or focus) from looking at where you are going.
Dan
[ATTACH=CONFIG]501493[/ATTACH]
BajaDan is offline
Old 06-02-2013 | 06:39 PM
I sat in the boat today and laid it out several different ways until I felt I had what was best. Having it on the left side allows me to use my left hand to make changes on the GPS and be able to keep my right hand on the throttles and not have to worry about pulling the lanyard out and killing the boat. I'm still intrigued with mounting it in the fairing to the left of the original panel. I can easily reach both locations (in the panel and to the left of the panel). Gotta make up my mind quick. My unit will be here tomorrow. I'll probably set it in both locations and see what I think. Thanks for all the help and suggestions guys, I appreciate it.
BGIII is offline
Old 06-28-2013 | 10:15 AM
Final product.
BGIII is offline
