Need help asap
Old 06-15-2013 | 10:16 AM
Originally Posted by Patience...myass
From the pic it looks like its broken off
Yup, that site has the look of having the head snapped off......
low_psi is offline
Old 06-15-2013 | 12:24 PM
like mentioned looks like it sheered off,try taking a center punch with a needle sharp point and put a punch mark on it,,noe hold the punch to the right and try tapping the end of the punch counter clockwise to unscrew the plug..
FIXX is offline
Old 06-16-2013 | 01:31 AM
Update here's what happen last owner put set of nose cones on and 5200 hundred them went as far as taking the 5200 over the drain plugs. I have never seen anything so crazy needless to say I spent all sat taking of 2 nose cones grinding down taking the bravo 1 s back to original.
32 Active Thunder is offline
Old 06-16-2013 | 01:32 AM
Thanks for the ideas!! I thought I was going f ing nuts
Old 06-16-2013 | 07:23 AM
Nose cones are only glued on? I didn't think 5200 was that strong. Wow!!
cp5899 is offline
Old 06-16-2013 | 09:55 AM
Yep,,did not think they were broken off because it would be leaking oil,,besides the bolt would have worked its way off been NOT a pipe thread,,
are you putting the nose cones back on?
boatnt is offline
Old 06-17-2013 | 11:12 AM
No I'm not putting them back on they are in great shape just need to be cleaned up!! If anybody wants them make me an offer or I need a bravo 1 tie bar with saddles would do some trading.
Old 06-19-2013 | 05:04 PM
Your Pachanga have AL numbers on it? I was the one yelling at you on sunday in the 353 fastech! I thought I recognized the boat. haha
FANTAZ28 is offline
