timing question.....
Old 07-11-2013 | 08:36 PM
540 Merlins
B&m 250's
5 lbs boost
32* @ 2500
93RM2
commandersander is offline
Old 07-12-2013 | 01:41 AM
Originally Posted by Full Force
true... But higher timing will detonate faster then lower.... Lower timing will also bring egt down a little supposedly... But yes too little timing will blow chit up too but I say a little low is way better then a little high!!!
Not necessarily. There are many factors to consider.
Less timing will most likely increase EGT's.
Running more timing, to a certain extent, and depending on the cam profile, can actually bleed off the cranking compression faster and reduce the risk of detonation.
Griff is offline
Old 07-12-2013 | 04:27 AM
Full Force's Avatar
I meant that but it came out wrong.... I just know for fact that 28-30 is a very SAFE zone with a blower in almost every application, not always, but MOST...
Full Force is offline
Old 07-12-2013 | 09:17 AM
Since we are talking about timing right now... with a non blower motor what kind of timing is safe for a SBC? My motor was just broken and the guy set it at 32 degrees at 3k. I was told I can up it to 34-36 for more power. Would this even be noticeable?
406 sbc
195/64 AFR
9.3 cr
nx262 cam
5.7 rods
750 edelbrock
Jackdonz is offline
Old 07-13-2013 | 09:33 PM
SFOcean's Avatar
Charter Member #394
Just try it, my 406 liked 36deg; bet yours will too.
SFOcean is offline
Old 07-14-2013 | 06:33 PM
Hopper's Avatar
Cast
Originally Posted by kvogt
alum or iron heads?
Hopper is offline
