How long will these drives last? Video
IF you have a ecu that's unlocked you can choose toggle injector banks during rpm reduction, one injector bank during rpm reduction mode or No Spark (No Dwell) When In Rev Limit or Stop Engine Mode, fwiw, Smitty
I may crank up that limit and hit that same spot this weekend. I run a tablet for gps and the speedo app max speed memory only stays until u shut it down, need a screen capture of triple digits
Not a bad idea however, I didn't realize the rev limit could be applied to each bank
Thats a good point. 3.5 pulley your buzzing that 256. If I remember correctly, I think you have the older style blowers. They handle the revs better and have better bearing set ups than the Newer Holley versions. But I'd keep an eye on them. When I had my 575's, I sent them to TBS and had them re-done every 100-150 Hrs. Wasn't that expensive. You'll put chillers on it next!!
I am running 120 stats no chillers, seems to work well. I have access to set a chillers, But haven't felt the need.
If I upgrade any further it's 871s and arneson drives
