Question--Outdrive Placement
New guy here .... trying to learn as much as I can about powerboats and hulls and especially outdrives (no real reason other than curiosity).
After looking at a ton of pictures ... I noticed that outdrive placements are a little different for certain types of hull styles. It appears that cats usually have a wider placement (again .. new guy ... but my thought here is that the outdrives for a cat have to be out wide simply because of the design of the boat?) After looking at some V-Hulls ... it looks like the placement is more varied. I have seen a ton of Outerlimit boats with a very close drive configuration ... while I have seen others with a much wider outdrive placement. I imagine that there are different handling characteristics based on the placement ... there is probably some type of performance/speed logic for placement as well. Thanks in advance for your help ... I have been on boats for years .. but nothing bigger or more powerful than a 26 foot Sea Ray .. my knowledge base is pretty low! |
To get drives closer together generally involves staggering the engines. Side by sides have wide deep drives and staggered lets you put both engines closer to centerline thus bringing drives closer.
| All times are GMT -5. The time now is 06:27 AM. |
