What to do with a boat that needs an overhaul (rot)? >
Old 10-10-2013 | 12:00 PM
Open pandora's box, take it apart, and attempt to fix it myself? Who knows how much time, youtube videos, and trial and error it would take learning to work with fiberglass. And then where would it stop?
Stringers, transom, raised x, new floor, bulkheads, glassed on deck, decent power (500ish), hydraulic steering, k-planes, etc etc. Maybe after all that work I wouldn't even want to sell it. It is only used on inland lakes, I don't really need or want twins or something a bunch longer. I know some of you must have been in this situation before, tell me your stories.[/QUOTE]
by the time your done with all that your going to have grey hair and an empty bank account. take the boat apart. sell it in pieces. and go buy something else.
88bullet is offline
Old 10-10-2013 | 12:09 PM
Originally Posted by seafordguy
My take - you're already checking out of this boat and excited abotu the next boat. I'd let this one be someone elses problem. Part it out or sell as a whole.
Nothing would be worse then jumping in, getting it torn apart and then trying to sell it because you've lost interest having moved on to the next boat.
Ditto, been there, done that. IF you do keep your head in it, and you DO finish it, you will probably be in it too deep to sell it and come out.
If for some reason you do decide to tackle it, maybe pay a few hundred for a surveyor to look at it and test it with their moisture meters. It would be worth the investment to know what lies ahead of you. A stringer can turn into a floor, can turn into a transom, can turn into a ................................
36Tango is offline
Old 10-10-2013 | 12:25 PM
Originally Posted by c_deezy
Engine stringer? If that's all that is bad, that's not too bad, and being in Texas you can probably work outside in the 'winter' I assume.
The wet part is down by the engine, though I have no idea how far up it has seeped. Working outside in the winter is doable just not ideal. It's not like I would have snow to worry about, just cold temps.
Crossett is offline
Old 10-10-2013 | 12:27 PM
You are correct. Mainly because running the thing flat out and only going 60 mph was getting a little old. The problem is that I was counting on the sale of this one to get enough funds to move into something faster. Now that it's worth considerably less than I thought it was i'm not comfortable with the loan I would need to move up.
Crossett is offline
Old 10-10-2013 | 02:30 PM
seafordguy's Avatar
It's hard to tackle something like that when you're checking out mentally.
seafordguy is offline
Old 10-10-2013 | 06:09 PM
ratman's Avatar
keep in mind the grain in the stringers runs fore and aft... it may have spread much father than you think...
ratman is offline
Old 10-10-2013 | 06:17 PM
Do you like the boat? Does it make you happy or are you "blah" about boating because of the boat?
indysupra is offline
Old 10-10-2013 | 07:04 PM
I like it a lot. It's the first performance oriented boat i've owned, it's also the reason I met my girlfriend. It's just not scratching the speed itch anymore and upgrading to a new boat seemed like an easier way to go when I thought I could pull money out of this one, not so much anymore. I've never been "blah" about boating. Even when i'm on my buddy's air nautique i'm having a blast. Just being on the water is what it's all about.
Crossett is offline
Old 10-10-2013 | 07:15 PM
I would fix it, it really isn't that hard.. I knew nothing about fiberglass when I did mine, but I jumped right into it got it done and off we went..
fleg1 is offline
Old 10-10-2013 | 08:24 PM
Expensive Date's Avatar
Talk, to someone like GlassDave about fixing it and then selling. If you pull the engine first it will be less money for him to fix.
Expensive Date is offline
