I still say the drives will be the weak point. Cautious or not, Your not wanting to add HP to baby the throttles. JMHO. What is the weight of the boat? what size prop and how many blades. These will all add to the stress on the drives.
Last summer before the starboard blew up or had any work done I was running abt 75. I blew the starboard engine in may and wasnt back in the water until end of aug. I was babying it for the rest of the season....
I was thinking the same... maybe should upgrade the drives first then look for hp??? I sit around 10,000 lbs with 4 blade 26p bravos
Which boat do you have? I had a 1997 36' with 525 SC's.
Thats the boat.
if you crank the boost up to 7 psi prolly gonna take out head gaskets!!!! bigger blowers sure.... if you have a stock bottom end... don't think it will last :party-smiley-004:
Bigger blowers , roller cam , headgaskets 625/650hp on snooze
Originally Posted by MILD THUNDER
(Post 4017369)
Originally Posted by Hopper
(Post 4017362)
| All times are GMT -5. The time now is 09:47 AM. |
