-   -   Saltwater perception - your thoughts (https://www.offshoreonly.com/forums/general-boating-discussion/305350-saltwater-perception-your-thoughts.html)
FIXX 11-14-2013 10:49 AM
yes joey,,your all set for salt water..you got the rite set up for salt water...the baja guy mis read what i wrote...
FIXX 11-14-2013 10:52 AM
Originally Posted by Keith Atlanta (Post 4026804)
Not if its a 525, 496, etc. They are closed cooled. Its all copper. I've had my heat exchanger off and it looks as good as 5 years ago.
no chit really..reread,,i wrote closed cooling which means theirs antifreeze running through the engine..i know about the 496 and 525's cooling systems..did not know joes already had closed cooling on his boat..
Wildman_grafix 11-14-2013 11:00 AM
Has anybody had problems adding a closed cooling system to a older boat that never had closed cooling and had been run in fresh water?
I was told by a builder he was afraid scale would clog the exchanger.
tbirdusa 11-14-2013 11:09 AM
yes, I would not buy a salt water boat without knowing the history of it. Yours, I'd buy it in a minute but I don't want to spend 30 grand on a boat right now.... you're asking 30 grand for it, right?
314joey 11-14-2013 12:13 PM
I figured you didn't know that I had a closed system, makes all the difference.
My boat was 10 years old when PBC installed them on mine, I bought a mercruiser kits just like would have been installed as if they were new and they work great, no problem at all, PBC did a great job.
If i can take the stereo/amps/speakers and one engine out................OK deal............lol.
The boat is like new, I bought it when it had 60 hours on it and I've taken excellent care of it, PBC re-built the top ends when they installed the flush-out/closed cooling, less than 80 hours ago.
Knot 4 Me 11-14-2013 12:19 PM
Originally Posted by 314joey (Post 4026838)
I think I'm all set-up, got the anti-freeze tanks all filled up right next to my 502s.
You did it up right with adding the closed cooling. That protects the engine block/heads/intake from saltwater. The seawater pump, power steering cooler, oil cooler, fuel cooler, heat exchanger, and exhaust manifolds/risers will still have saltwater exposure. Very nice setup.
314joey 11-14-2013 12:33 PM
Thanks for the nice comments, with anything I've ever owned I figured if you're going to do it, do it right, or don't do it, I had PBC pulled both engines and pretty much went through both engines, rebuild them and install the goodies before I had bajaholic (Brian) haul it down here, I didn't want any problems out in the open water.
Someone will eventually get a nice 353 when it's available next Spring.
sailtexas186548 11-14-2013 01:04 PM
Originally Posted by runninragged (Post 4026846)
salt away is apretty good product running in salt water going to get some corrision but proper flushing will heip
We have always flushed our volvo small block boat, but when we started using salt away it was obvious the improvement just by looking as the water flow out of the outdrive when on the hose (flush kit between the waterpump and outdrive). The stuff is great
we put a closed cooling system on that same boat ^ after 200 hours of use, at 500 now and we have not had any issues with scale in the exchanger
pstorti 11-14-2013 03:49 PM
Since moving down here all my boating has been in salt and while you can keep your boat pretty perfect if you try, the salt will corrode anything and everything if given the chance. Obviously if there were two identical boats for sale and one was from fresh water use only nobody on their right mind would buy the one used in salt. When I bought my previous boat it was from a guy in Las Vegas, I went there to sea trial it and they took me out for the day, it was awesome to just pull it out of the water take the trash out and be done! No rinsing, no flushing, and no washing! I'll take the beauty of the ocean and the hassle of the salt that comes with it though, as long as the boat has been properly cared for nothing wrong with a salt water boat.
Jupiter Sunsation 11-14-2013 04:47 PM
The biggest irony of the "fresh water only guys" is they have never boated in salt water yet there were 200+ boats in Key West last week, some exceeding a million dollars in value that all were in the evil salt water......
Pretty much every MTI, Skater, Outerlimits, Cig, Nortech etc........................All hit salt water at some point in their usage and they all come out ok! :D
