what are these holes in the bottom of this OL >
Old 11-17-2013 | 07:42 AM
bwd
Out of curiousity, I did back to back runs on near flat ocean water this pat summer. One , with tape over the intakes, one without . 4.4 mph faster without.
bwd is offline
Old 11-17-2013 | 12:54 PM
Thumbs up
"4.4 mph faster without."
So it worked as it should, breaking up surface tension, right? Most boats run faster in slightly choppy water.
spectras only is offline
Old 11-17-2013 | 01:28 PM
I wanna run 3 inch tubing from in front of my windshield. ( like the cowel are on a car) to my steps along the outer part that gets less airation. You would think it would get pressurized prety well at 100 mph.. This would have to remove drag.. And if the tubes are above the waterline no water would come up? Or check valve it. Thoughts ?
mcprodesign is offline
Old 11-17-2013 | 02:04 PM
bwd
Just to clarify the conditions when I did it. This was a spur of the moment thought as I was backing the trailer down the ramp one evening to go try a new set of props( which stunk). The ocean bay was like a mirror with a slight ( very slight) roll . No chop, no wind, no swell. 1 point of interest was when i tore the gorilla tape off, it was concave in shape which leads me to believe there may be vacuum from the water running under the step which pulls the air in from the sides.
bwd is offline
Old 11-17-2013 | 05:59 PM
That's flat water and that why they used in the Biesemeyer I posted before. Drag boats only run on flattest water. V hulls like even the smallest chop and the bigger the better which does the same thing.
If you run the lines above the water line it would be fine unless you back up fast enough that you push water up the tubes.
f_inscreenname is offline
Old 11-17-2013 | 06:14 PM
The badazz chief is having success with venting the steps
offshorexcursion is offline
Old 11-17-2013 | 07:54 PM
Anybody have pics of this?
Old 11-17-2013 | 09:13 PM
TeamSaris's Avatar
Driver-441
Racer
There are a few old 21 Challengers with forced vented steps
TeamSaris is offline
Old 11-17-2013 | 10:13 PM
If there was a chief section they would be easy to find................................oh wait money and politics on OSO my bad.......
Old 11-17-2013 | 10:21 PM
force has 4 threads and their own section, lol there are more for chief in the general section.
professor_speed is offline
