GPS speedo hook up/antenna >
Old 11-24-2013 | 09:07 AM
Page 27 says it has an NMEA 0183 output
troper is offline
Old 11-24-2013 | 12:02 PM
anybody have luck Replacing the battery in a Livorsi set up. I tried soldering one in and It still doesn't pick up.Kinda hard to get a hold of Livorsy but the said I have to buy a new one.. seems a waste but that's what they said
mcprodesign is offline
Old 11-24-2013 | 02:29 PM
Thats the reason I hooked mine to the Lowrance,
troper is offline
Old 03-09-2014 | 11:18 AM
How do you wire it up? Just picked up a elite 4 and was trying to figure out where to hook up at?
neversatisfied23 is offline
Old 03-09-2014 | 11:30 AM
I have asked a similar question some time ago (didn't get any comments back ) Can I use the Garrfieg Speedo GPS antenna on a Garmin GPS/chart plotter? or the Garmin antenna (internal) on the GPS or on the vessel view?
PARADOX is offline
Old 03-09-2014 | 01:52 PM
My unit says it has the nmea 0183 output but only two plugs on the back for transducer hook up and one for separate speed temp sensor.
Old 03-09-2014 | 02:01 PM
I have the HDS7 and wired the Lorvisi GPS Gauge to the NMEA183. I'll see if I can find the instructions.
troper is offline
Old 03-09-2014 | 06:12 PM
Dave M's Avatar
Veteran: Navy
Yes, You can connect your GPS speedo to your Garmin GPS w/internal antenna. If I recall, the blue wire coming off the GPS harness connects to the signal wire of the speedo.
Dave M is offline
Old 03-10-2014 | 06:21 AM
[ATTACH=CONFIG]520043[/ATTACH]
troper is offline
Old 03-10-2014 | 07:51 AM
lastcall02's Avatar
Has anyone ever hooked their Lorvisi GPS to a Garmin 3206? If so, how did you do it?
lastcall02 is offline
