NXT Transmission Blown Apart >
Old 12-04-2013 | 10:40 AM
RMPRam's Avatar
Originally Posted by el indio
hello gary..its been awhile. how r u doing? u all have a good holiday season............................mm......
Fine, except it is going to snow 8-10" in Minnesota today. Take care Mark.
RMPRam is offline
Old 12-04-2013 | 11:32 AM
I think Bam had an actual transmission conversion with mounting plates and all. Was suppose to be a complete replacement kit. Has anyone converted to those? Seems like a lot of those NXT transmissions fail or get stuck in gear. When we were out at Bocca a few weeks ago a 39 top gun beached next to us stuck in forward. I know another guy with a 36mti same thing happened and one of our fellow SCOPE members has gone through 3 or 4 of them on his 44 Hustler. What's the down side of putting an actual transmission in?
tim mccray is offline
Old 12-04-2013 | 12:46 PM
bill63's Avatar
Fast Priorty II Nor-Tech
Same thing with a friends 39 Nortech beached it on Bocca Grande key during the worlds and got stuck in reverse. Its at Bam now.
bill63 is offline
Old 12-04-2013 | 02:48 PM
Tom A.'s Avatar
Originally Posted by PremierPOWER
How do they like them?
My friends are happy with them now. I believe there was a learning curve when they first came out so to speak but they seem to have figured it out and they have been holding up well.
Tom A. is offline
Old 12-04-2013 | 03:06 PM
Brand x was working with bam doing a couple r&d installs. The nxt trans is a bit shorter than a velvet drive which nessecitated a whole new design iirc.
Unlimited jd is offline
Old 12-04-2013 | 03:26 PM
lr any pics on that by any chance?
noli is offline
Old 12-04-2013 | 03:53 PM
Panther's Avatar
Frank's Marine Service
That transmission is really a little mini Bravo so I guess you can't expect too much from it.
Panther is offline
Old 12-04-2013 | 04:17 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Exactly. It's virtually NO different than the cone-clutch in the top of Bravo drive. You just don't destroy a full drive when parts merge with the drive fluid and turn into applesauce with the NXT.
Sydwayz is offline
Old 12-04-2013 | 05:24 PM
I had similar issues with my NXT transmissions so I replaced them with Huber 1450s, which are based on the same Borg Warner 72C as the BAM. They are both good units and either one will be much better than the NXT. Haven't had a transmission issue in five seasons since the swap.
GF?
Got Freedom? is offline
Old 12-04-2013 | 05:35 PM
Mbam's Avatar
Offshoreonly Advertiser
Here are a few pictures of the kit. A driveline setup is no problem, the plug-in is much more involved. We had to make our own very short tailstock and extension box to avoid moving the engine.
I'll see if I can find some pics of the actual install.
Attached Thumbnails NXT Transmission Blown Apart-linkkit.jpg   NXT Transmission Blown Apart-cyborg-018.jpg   NXT Transmission Blown Apart-imag0169.jpg
Mbam is offline
