Can a 496 be damaged with freezing temps?
Yea I asked if it was a closed system in pervious post. So the heat exchangers use fresh water? Not real familiar with the closed system engines.
He's in trouble. Those heat exchangers are probably toast, and maybe more.
I know I've posted at least 100 times on this topic so there is plenty that will come up with a search. The 496/HO water drain actuator system is NOT to be used for winterizing.
If these exchangers freeze and bust, the boat will take on water next year and not cool the motor correctly.
Like I said, there is a little hand pump to blow the exchanger down to extend the season, but in cold envionments were it is below freezing for exended days and nights, it will not be enough.
If his "friend" would have done the blowdown and put it inside a building, I would say he would be fine for now.
Around were I live, you could have picked up the phone and a service place would come out, winterise and even place it in storage for you and just send the bill.
Yeah, the heat exchangers draw fresh water and cool the closed system antifreeze.
And yes, same around here also. I keep mine at a marina and winterize it myself for a few years now and they still call me to make sure I did.
Worse yet, how is your friend on overall maintenance and upkeep? If there have been any previous issues with antifreeze/freshwater crossing over, he could have water in the block and that would freeze.
IF the antifreeze tank appears pink, there would probably be enough antifreeze in the "solution" in the block that would protect from freeze damage to the block. Such was just a passing thought though.
Alot of fly by night operations could cost us too much money
cutting corners.
I use a stand up dealership that would stand behind any mistakes. They have a big tank and recycle plus they use a hydrometer to ensure what temp I am good for.
I always hate to see winterisers dump on the ground and am scared to death to walk my dog around the marina this time of year.
I'm sure you do a great job. I guess this "friend" may learn an expensive lesson.
I think that Mercury says to check the antifreeze as part of the winterization process, as any small leak could be cause for cross contamination. Assuming that the antifreeze is good, the block should be OK, but I bet the exchanger, cool fuel, exhaust, pump, etc. are toast. It is amazing how a small amount of water can freeze, expand, and crack big hunks of steel. That said, for your friends sake, I hope that he is safe.
If it thaws and then freezes again, the water from the busted exchanger could very well dilute the antifreeze to the point that the block coul crack with the next cold temps.
Please let us know how it all turns out.
