Trim Switch For Offshore Controls >
Old 01-07-2014 | 07:03 PM
Originally Posted by mptrimshop
What would it take to turn a piece on a lath and put a switch in ?
this fit my kk controls
smokin' gun is offline
Old 01-13-2014 | 12:24 PM
Originally Posted by smokin' gun
heres a nice cheap way to do it ive done many like this.the older zero efforts without trim in handle can be converted easily .there is 2 screws under the cover on the throttle where the trim would go .remove those and drill a hole for the wires on the new switch to run down .i usually use a piece of black shrink tube and a small tie wrap to keep it in place.any ways the switch is on ebay great lakes skipper has em ive done many this way
ebay item # 400637260928
I used this trim switch like Smokin' gun suggested, here is a link for it:
http://greatlakesskipper.com/baja-fo...ol-trim-switch
This worked well, it fit tight, actually had to do a little sanding then tap it in, and had to buy longer screws as the ones provided were to short(was .27 cents for the 2 screws at my local sears hardware store). Is a really clean finished product, easy to install in KK controls, and cost is a no brainer. Here are a few pics:
ealesh33 is offline
Old 06-05-2015 | 07:03 AM
Bringing back a old thread. I just received my switch from GLS yesterday and can't wait to get rid of the crappy switches on the wheel. I started having a issue last week where the drive trims itself up when idling, I think water got into the helm when we got caught out in a storm. Also you have to play with wiring to get drive to trim at times. Do I simply disconnect wiring to helm and wire straight to this switch?
RNGRDVE is offline
Old 06-05-2015 | 02:51 PM
RNGRDVE, fill me in on your switch. I need to do the same on the throttles of my 2800!
JUPITER PULSARE is offline
Old 06-09-2015 | 12:31 PM
Steve it worked well. I haven't been on the water yet but installed it on Sunday and it does the job nicely. I'll pm my #, Shoot me a message and I'll send some pics.
edit, your mailbox is full. I sent a message on the Checkmate forum.
RNGRDVE is offline
Old 01-22-2016 | 10:32 PM
I did exactly that! If anyone is interested I have a few more I made as some people have shown an interest in it. Also drilled the hole under the handle and made a stainless tube to run wires through. PM if interested.
Attached Thumbnails Trim Switch For Offshore Controls-image.jpg   Trim Switch For Offshore Controls-image.jpg   Trim Switch For Offshore Controls-image.jpg
89Mach1 is offline
Old 08-10-2017 | 11:01 PM
I know it's an old thread but would you happen to have a trim switch for Kiekhaefer control left?
thanks in advance
Cway27 is offline
Old 12-25-2020 | 11:32 PM
Default Switch
I know it's really old thread but does anyone have this available to buy
Baja 250es is offline
Old 03-19-2021 | 09:56 AM
Hi
It's very difficult to find !!
new or used...
bajalux is offline
Old 06-20-2023 | 09:28 PM
Yes, old thread but I can't PM 89Mach1 (newbie) looking to see if any more switches being made?
thank you
kw
kawilliams is offline
