-   -   merc freshwater flush (https://www.offshoreonly.com/forums/general-boating-discussion/307922-merc-freshwater-flush.html)
BUP 10-28-2014 12:03 AM
if your intake grates are under the hull then get fake a lake water flush like what we use for the wakeboard boats.
Google fake a lake
it looks somewhat like a toilet plunger but can be adjusted in heights. We use it all time for those style of intake grates under the hull. as all the wakeboard boats commonly have this set up.
If you have transom mounted water pickups for the water intakes engine cooling side then fake a lake will not work
Mr Maine 10-28-2014 06:17 PM
My formula 272 has fresh water dockside flush. Hose fittings for each engine. It tees into the sea line from the outdrive, with I assume a check valve on the sea side. I now have the same issue with trs. I take the caps off the sea strainer and put the garden hose in it, works fine for now
way2fast 10-28-2014 06:20 PM
they are not under the hull just at the transom... like the old flatdecks foxhunter and tag and release on here..
here are some examples look at the transom photos in the centre
http://www.offshoreonly.com/classifi...o58409-en.html
http://www.offshoreonly.com/classifi...o59193-en.html
way2fast 10-28-2014 06:21 PM
http://cleveland.craigslist.org/boa/4671192822.html
Mr Maine 10-28-2014 06:21 PM
Why is my response 2 posts back?
gsxrmike 10-30-2014 12:14 PM
1 Attachment(s)
Originally Posted by way2fast (Post 4064465)
I want to run my 2005 merc 502's on the hose…. but can't find where to put the hose… do I need an after market fitting??
thanks
[ATTACH=CONFIG]531765[/ATTACH]
For what it is worth here are where my fresh water flush is, and yes you need a plastic connector that goes on the end of a garden hose that is a quick disconnect into the fitting under those blue rubber caps that I circled.
