anyona work at a GM dealership
programming one is fairly easy put a charger on the battery as the ign will need to be on for 30 plus minutes insert the key try to start the veh release the key let the veh set until the security light stops flashing repeat this step 3 times should take ten minutes each time in this sequence do not turn the key to off .... the fourth time you turn the key it will start
