-   -   Need bmw mechanic (https://www.offshoreonly.com/forums/general-boating-discussion/309588-need-bmw-mechanic.html)
moparjet 03-19-2014 11:13 AM
Originally Posted by TURBO JET (Post 4091015)
What year car do you have and motor?
what he said
JIMKID Motorsports 03-19-2014 05:38 PM
2007 328 xi and no I did not set the motor before pulling it off and did hear a springing noise when removing the motor
Bad Ass TA WS6 03-20-2014 06:55 AM
Wind the 4mm allen @ the back of the valvetronic motor clockwise by hand until it stops. Remove the motor and check the base flange and ensure it is flat/straight. Sometimes it helps to wind the motor counterclockwise slightly to get it out. Same goes when you reinstall, wind clockwise and make sure it is fully seated/lined up with the holes, then install the 3 bolts. Cycle the key (start/stop) and listen for the valvetronic to do its full sweep.
No misfires or faults correct?
Bad Ass TA WS6 03-20-2014 07:07 AM
Also ensure the valve cover gasket hasn't fallen out of its groove/oxygen sensor wiring isn't pinched at the rear of the cover. Use a mirror and check around the whole VC
prostock3 03-20-2014 07:42 AM
i live down the street from you, im in Walled Lake, been working for bmw for 10 years. I can swing by. I also believe we meet at the Kielian bday party.
The 30 ft Skater with LS7, not too many out there.
moparjet 03-20-2014 11:03 AM
also check the crank vent hose at back of valve cover. make sure its secure and not cracked
