502 mag
Old 03-13-2014 | 02:37 PM
Default 502 mag
what does everyone think of a 2000 502 mag mpi with 150 hrs. bone stock
stingraysx22 is offline
Old 03-13-2014 | 02:58 PM
They came in a variety of boats.
redwhite is offline
Old 03-13-2014 | 03:06 PM
onesickpantera's Avatar
They are black.
onesickpantera is offline
502 Mags are great engines. Very reliable if well maintained.
Old 03-13-2014 | 04:20 PM
Send it on over.
Hook'em is offline
Old 03-13-2014 | 06:20 PM
ratman's Avatar
Originally Posted by onesickpantera
They are black.
yeah but i think the 350s are too, how can you tell em apart, they both have 8 cylinders and a carb thingy on top
ratman is offline
Old 03-13-2014 | 10:30 PM
Actually RM, it's EFI.lol No carb thingy.
The 502 Mag is an excellent engine. Pretty tame piece that will run a LONG time. That year is a much later model with much better parts, like cool fuel, Mefi 3, serpentine accessories, etc. Tough to go wrong with it as long as it checks out.
Eddie
Young Performance is offline
Old 03-14-2014 | 08:14 AM
They have pistons the size of Folgers coffee can's
Clogged/dirty injectors will cause the engine to lean out.
Stupid vent in VST tank cost $86 fora piece of rubber, and when it fails, it washes down #8, and thins out your engine oil.
They have a tendency to vapor lock witch is embarrassing when you idle threw a long channel in the heat, hit the sticks at the end and the engine stalls out. Skanks now leave your boat and get on a fountain
Top end is recommended around 500hrs I believe. They CAN blow head gaskets.
Heads weigh 75+ lbs, so do the exhaust manifolds.
Very reliable engine, and saying 502 mag has a catchy tune
You can lay on top of the engine in comfort (to a point) to work on impeller, plugs, wires.
92nsx is offline
