Angle bracket to stringer for engine mounts ???? >
Old 03-30-2014 | 03:58 PM
vintage chromoly's Avatar
Default Angle bracket to stringer for engine mounts ????
Hello all.
I'm in the process of mocking up my driveline in my 24-7 project.
The combo is a bravo/bbc.
My question is in mounting the engine to the hull. Specifically, is it ok to use a standard rubber isolator type engine mount bolted down to a 1/2" thick aluminum angle bracket bolted to the stringer? Dana marine sells extruded aluminum angle for this purpose.
Here's a pic of a piece of 1/2", 6 by 6 aluminum angle I have mocked up. Will this be an acceptable install?
I would machine the angle "horizontal" back a bit and through bolt it with a backing plate.
Thoughts much appreciated.
Thanks, rob
vintage chromoly is offline
Old 03-30-2014 | 04:01 PM
I would add 2 gussets.
Pwraddr is offline
Old 03-30-2014 | 04:06 PM
That would scare the heck out of me.
Black Baja is offline
Old 03-30-2014 | 04:12 PM
How is it generally done? When does one step up to an "offshore" style mount?
How do production boats come? I thought they used aluminum angle.
Old 03-30-2014 | 04:29 PM
Dana marine brackets:
http://www.danamarineproducts.com/Pr...b-6a1c7129e492
Is this "aluminum angle bracket" mounting method suspect?
Old 03-30-2014 | 04:34 PM
That aluminum plate will snap in a horizontal position. Most offshore style mounts would have the aluminum plate mounted vertically so you need to turn the mount 90 degrees. That means a differewnt engine mount. They take a lot of punishment.
Wannabe
wannabe is offline
Old 03-30-2014 | 04:54 PM
c_deezy's Avatar
That's the same way I did mine, with two slight differences.
1) I used 4x4x1/2 aluminum angle
2) The top of my angle was about 1/4" below the top of my stringers.
If your engine mounts were all the way out to the other edge or the horizontal piece, I might be a little concerned. If your end result is like how you showed, I wouldn't be concerned about it. Basically your engine mounts are pretty much above the vertical of the angle iron, although you are a little tall on how far above the stringer the able AL is.
Another way you could do it is use two pieces of angle on each side, to saddle the stringer and bolt them together with the bolts used to hold the engine mount to the angle.
c_deezy is offline
Old 03-30-2014 | 05:51 PM
Wobble's Avatar
SORE MEMBER
I went with the full offshore mount setup from Teague, I think what deezy suggested might be a clever way to brace it
Wobble is offline
Old 03-30-2014 | 06:01 PM
Dave M's Avatar
Veteran: Navy
Here's a pic of the mounts that where in my 24 Superboat. I am not a big fan of the stock Merc. mounts, but the through bolted angle iron was pretty solid. I drove the boat like I stole it and didn't have any issues.
Attached Thumbnails Angle bracket to stringer for engine mounts ????-2005_0127_104649aa.jpg
Dave M is offline
Old 03-30-2014 | 06:13 PM
I've seen many boats done like that. Only thing I'd do is add a small gusset and it will be fine. Make sure you use a good backing plate on the other side of the stringer
Unlimited jd is offline
