XSpower HEADERS
Old 04-14-2014 | 11:45 AM
  #31
the deep's Avatar
Fast Singles Club
Veteran: National Guard
A nice stainless header for a REASONABLE PRICE !! It's about fu$#in time someone breaks the stranglehold a couple manufactures have on us !
the deep is offline
Old 04-14-2014 | 12:12 PM
  #32
C_Spray's Avatar
Diamond Member #001
321 is generally used for very high-temperature applications. We used it for Indy car headers before we switched to Inconel. I'm not sure how well it holds up to saltwater corrosion versus 316L or 317. If nothing else, it looks as if all the primary pipes are the same length.
C_Spray is offline
Old 04-14-2014 | 12:15 PM
  #33
vintage chromoly's Avatar
Do they sell the matching tail pipes?
vintage chromoly is offline
Old 04-14-2014 | 01:11 PM
  #34
Originally Posted by BUP
Talked to Rich @ XS about a month ago about these. He said they were they were made from 321 stainless. That is not a cheap stainless to buy. Are you the same person who posted these over on performanceboats.com in the forum ? Just asking.
No i didnt. I orederd these and in two weeks they were here!
Bulitz is offline
Old 04-14-2014 | 01:25 PM
  #35
321 Stainless Steel
Type 321 stainless steel is similar to Type 304 stainless steel, however, it contains a Titanium addition of at least five times the carbon content. This addition is made to reduce or eliminate chromium carbide precipitation - resulting from welding or exposure to high temperatures. Maximum stabilization is accomplished by annealing between 1750° and 1850° F. Type 321 has extensive use in aircraft parts, such as exhaust systems where operating temperatures are higher than 800° F. and where corrosive conditions are not too severe; also because of its resistance to scaling and vibration fatigue.
Typical applications: Aircraft Exhaust Stacks and Manifolds, Chemical Processing Equipment, Welded Equipment, Jet Engine Parts, etc
316 Stainless Steel
Type 316 stainless steel has better corrosion resistance to most chemicals, salts and acids and is more resistant to marine atmosphere because of an addition of 2.0 to 3.0% molybdenum. This addition improves the corrosion resistance of austenitic steels and imparts hot strength characteristics. Another valuable property of Type 316 stainless steel is high creep strength at elevated temperatures. Fabrication characteristics of Type 316 are similar to Type 302 or 304.
Type 316 stainless steel has extensive use in chemical processing equipment when better corrosion resistance is required than is afforded by chromium-nickel steels. Also 316 is specified for use with high purity products where product contamination must be held to a minimum. Typical applications are Food Processing, Chemical Processing, Photographic, Pharmaceutical and Textile Finishing Equipment and Marine Exterior Trim.
FIXX is offline
Old 04-14-2014 | 03:52 PM
  #36
Wonder if they could duplicate my Steroid Stellings so i don`t have to have new tails made? Where are you guys finding pricing?
ICDEDPPL is offline
Old 04-14-2014 | 04:06 PM
  #37
How hard could it be to just weld tails on? An inner piece and an outer piece...
Easy, or at least it seems like it would be. I added 6 inches to my Dana risers an it seemed easy.
Keith Atlanta is offline
Old 04-14-2014 | 04:23 PM
  #38
SB
Time will tell.
People who buy them please report over the next few years on how well they hold up and what kind of boating you do...ie: river, small lake, big lake, Apache only type seas...lol, how many hrs, and etc.
SB is offline
Old 04-14-2014 | 05:02 PM
  #39
the deep's Avatar
Fast Singles Club
Apache ? Just beat on a set with a sledge hammer and run over them with your truck then pressure test . Share the results with us........
the deep is offline
Old 04-14-2014 | 07:18 PM
  #40
Im in the market for new headers. This may be a good option. At that price i could modify them to work with my dry tails.
Rbesola is offline
