OIl recomedations
Old 04-17-2014 | 08:39 AM
Valvoline 30 wt Racing Oil VR1. Not meant for street use so has the zinc in it.
Wannabe
wannabe is offline
Old 04-17-2014 | 03:52 PM
Wobble's Avatar
SORE MEMBER
Originally Posted by cig92
is the zddp the zinc? doesn't valvoline 20/50 racing still have zinc in it? btw, good info, i wish all forums were this simple and non polluted
You will find zddp in oils that will not see a cat convertor, right now that means race oils and better motorcycle oils like M1 V-twin 20/50 or their 4T 10/40 motorcycle oil.
Several years back Mobil wrote a letter to a user here confirming that the V-Twin was their oil most suited for HP marine use.
Wobble is offline
Old 04-17-2014 | 05:20 PM
MissGeicoRacing's Avatar
Racer
Royal Purple.
MissGeicoRacing is offline
Old 04-17-2014 | 08:24 PM
Rotella 15/40. I run it in everything I own( 2 Big Block Olds1 SBO, 2 SBC and a502 MPI plus the truck), . Hillbilly logic dictates if it will protect a 14 liter Detroit making over 1200 ft pounds of torque, it should protect the smaller ones as well.... 2500 HD Chevy with an 8.1--I do let her warm up a little when it is below freezing.....LOL!
mallatt442 is offline
Old 04-17-2014 | 10:12 PM
Wobble's Avatar
SORE MEMBER
Originally Posted by MissGeicoRacing
Royal Purple.
RP is a marketing company that contracts a blender to make their products and add a dye. I will stick with ExxonMobil R&D's Mobil 1 products
Remember splitfire sparkplugs?
Their HQ is a few miles away and I can assure you thatit is no refinery
Wobble is offline
Old 04-17-2014 | 10:56 PM
I personally use Synergen in my race engines and motorcycles.
It's very hard to argue with Rotella T though. It's economical and easy to find, as well as an excellent oil.
rev.ronnie is offline
Hey, you can't blame a guy trying to pay the bills. Personally, Mobil 1. I use Valvoline dino oil to break in my engines though.
abmotorman is offline
Old 04-18-2014 | 09:40 AM
On Time's Avatar
I have had V-6's and V-8's since 1982. I have had 2 boats the entire time, and 3 the last 5 years. I have used:
Rotella 15W-40.
Delo 15W-40.
Pennzoil 10W-40.
Last 10 years Mercruiser 25W-40 dino until semi-syn 25W-40 became available. I always change at the recommended intervals or before. Result? No oil related failures of any kind. Ever. So does it really matter as long as its a quality oil????
On Time is offline
Old 04-18-2014 | 10:46 AM
What is your thoughts on Brad Penn? I have been using Sae 40 with no issues. I pay a fortune for it!! If Rotella works just as well, I would rather use the extra cash for more fuel!!
smckie is offline
Old 04-18-2014 | 12:17 PM
That is a crock. Where did you ever hear such a thing? They are by no means a marketing company. All synthetic oils are a base oil, which there are only but a few companies that produce the base oil.........Mobil is of course one. The additives are than purchased from a company, most use lubrizoil (spelling?), and mixed together like cool aid. In most cases it's the same for all the oil. Royal Purple buys the additives THEY request and together with much of their own products they produce their oil. Royal Purple began their company as an industrial supplier and trouble shooter. If you had a lubrication issue they are called upon to find a cure. Their biggest customer was and still is Mobil/Exxon. The oil was just an offshoot of this highly successful company. It was started by 3 PHD chemist and recently sold to Calumet Industries which is a publicly traded company on Wall Street. Marketing company, geeeeeez give me a break.
benjen is offline
