How do I fix bumper rub on my gel coat?
SubscribeHi All
Can anyone tell me the best way to fix my gel coat that has been faded where the dock bumpers were rubbing? Tried wax but did no good.
Ken
Ken
Ken
Originally Posted by Knott Workin
Hi AllCan anyone tell me the best way to fix my gel coat that has been faded where the dock bumpers were rubbing? Tried wax but did no good.
Ken
Gotta hit it with a buffer and some compound. Depending how bad it may have to be wet sanded as well, but most times the buffer does the trick
if it is just scuff from the bumper no rash you may be able to get away with wiping it down with acetone then give it a polish by hand,otherwise like the other guys posted wetsand and polish.pics would help to determine the best way to help you go about it.
I've had great results with 3M super duty rubbing compound followed up with a finer finishing compound and then a glaze. I use a orbital polisher.
Be careful or you'll end up getting sucked into doing the whole boat if it really pops!
offshorexcursion
close
- Join DateMar 2008
- LocationTraverse City MI
Liked:375 Times in 134 Posts
Quote:
Yes....repaint Originally Posted by Tinkerer
Is there any way to get power steering oil stain off the gell coat inside the engine compartment?
The bilge paint usually breaks down before the exterior because it is never protected (wax) You paint is old and has become porous, which invites staining letting new oils into your oil based paint. New paint has gloss and is basically a sealer that will repel staining.
I will try buffing with compound.
HI FASTDONZI
There is no gash it is just rubbed dull. I had the boat tied up too tight.
