Cig twin step w/575s
Old 04-23-2014 | 07:58 PM
Default Cig twin step w/575s
Are 30 pitch bravo 1s common on 575s with a twin step? These motors are re built by Ron potter and have the Arizona speed shop pulleys, and also have ported and polished heads- there dynoed at 700 hp, we ran the boat up to 84 and had trim and power left, also tabs were at 3, don't remember the RPMs , my question is- do 30s sound right for this set up- or would 32s seem more logical?? Thanks for your input!
Unlimited39 is offline
Old 04-23-2014 | 08:02 PM
32s or 34 4 blades or 5 blades
endeavor1 is offline
Old 04-23-2014 | 08:10 PM
I've got a set 32. 4 blades Jason if you wanna try em
QWKRN U is offline
Old 04-23-2014 | 08:18 PM
Don't the 525 boats come with 30's? At 700 hp you're gonna need 34-36 if think
Unlimited jd is offline
Old 04-23-2014 | 08:35 PM
H20 Toie's Avatar
My 525 boat has labbed 32s
H20 Toie is offline
Old 04-23-2014 | 09:25 PM
32's on mine as we'll, 525's
jbraun2828 is offline
Old 04-24-2014 | 05:25 AM
Biggus's Avatar
FWIW... My 30 Cigarette Mystique T/S ,ITS, Sportmasters, std length, 575SCi's with similar mods was delivered with Labbed (Mercury Racing) 37p Bravo One 4 blades.They deliver a very strong top end but slip at mid range cruise is too high for my liking. My everyday set of props are 15.5 x 34 Hering 5 blades. They work incredible, very efficient @ cruise and strong on top end too. Given the additional weight of your boat, I'd suggest a pair of 32 Hering 5 blades. Call Jeff @ Hering, he'll set you up.
Kurt
Biggus is offline
Old 04-24-2014 | 07:04 AM
EvilTwin's Avatar
My 2002 T/S 38 TG had Stock 575's and had stock 32's Bravos and would run 5000-5100 rpms at 89-90 mph best. So I would say if staying with bravos going to 34 or labbed 36's.
EvilTwin is offline
Old 04-24-2014 | 12:08 PM
just had a long conversation on this very topic. 30-32 4 blade seem to be the props of choice for most stock TG's. over here in CT there is a TG TS with stock 575 power. he is running 32 4 blade. not sure what he does for numbers.
1MOSES1 is offline
Old 04-24-2014 | 12:22 PM
Have 2 2003 ts guns 1 525 xr sport master w it's 32 bravo 1 labbed
Other boat same drives only 575 same props 32 labbed both boats same mph
Only diff 1" spacer in 575 boat both run 90 gps
smokin' gun is offline
