-   -   Changed to Amsoil and list oil pressure? (https://www.offshoreonly.com/forums/general-boating-discussion/313949-changed-amsoil-list-oil-pressure.html)
236eagle 06-17-2014 11:29 PM
I was using M1 5/50 and had 65lbs oil pressure then changed to 20/50 Amsoil and lost 25lbs of oil pressure ? What's up with that? Anyone else have this issue? I checked sending unit and it's working fine. I don't understand what happened. Your comments please. Thank you
Rwbrew3 06-17-2014 11:39 PM
I read a thread earlier this week where a bad filter was causing low oil pressure! Just a thought if all you did was change the oil and filter..
Wobble 06-18-2014 08:43 AM
Certain cheap filters can collapse internally causing that kind of pressure loss. For sure, try another filter before anything else.
236eagle 06-18-2014 09:01 AM
Thank u guys so much! It is a Ph5 fram. I will change it! Thank u for your replies
skydog 06-18-2014 10:16 AM
Ph5 fram JUNK man don't run them. Wix or napa gold same filter good stuff
ALL_IN! 06-18-2014 10:34 AM
And you can generally get an Amsoil filter from the same place you buy your oil.
236eagle 06-18-2014 10:35 AM
Got it will do. I will install napa filter and post results. Thank u for your reply
Wobble 06-18-2014 10:41 AM
One other thing, your new oil bottles had an intact seal on them?
I recently was sold some Mobil 1 v-twin synthetic oil bottles that had used oil in them.
skydog 06-18-2014 11:15 AM
Make sure Napa Gold filter :-)
TylerBurich 06-18-2014 11:46 AM
1 Attachment(s)
[ATTACH=CONFIG]524852[/ATTACH]
Filters are for same application
