need info oil change pump
Old 06-26-2014 | 10:04 AM
Jabsco all the way I have 2 of them ...only 1 out there that will pull the oil out of a cold motor
Takes about 5 min on a cold motor 1 min if Hot
smokin' gun is offline
Old 06-26-2014 | 10:34 AM
whats the model # or picture / link
Priobe is offline
Old 06-26-2014 | 10:45 AM
This is the one I have and it works great. http://www.jamestowndistributors.com...iwCvJGhUbw_wcB It also comes in handy if you want to change your transmission fluid in you cars.
JWay is offline
Old 06-26-2014 | 11:19 AM
So far I've used this, http://www.harborfreight.com/12-volt...pump-9576.html, once on both of my engines and it worked well. I know what the description says but I tried it anyways and when it fails it should be pretty simple to open up and change seals.
ramos45 is offline
Old 06-26-2014 | 12:01 PM
WEST MARINE
Manual Oil Extractor - 6.9 Quart
Model # 11047123 | Mfg # CJ-169SWM
It is a tall semi clear cylinder that has the quarts marked off - vacuum pump.
I use it for oil changes as well as getting small amounts of H2O out of the bilge that the pumps don't get.
I've used it for three years so far. $84.00
Wes Burmark is offline
