Looks like a poor surface weld to me.
When we weld them I grind the skeg and case to a V to ensure a deep, strong joint. Even then the cases are large heat sinks and with no preheat require 250-275 amps to get the party started.
Should have brought it north.......always cheaper to do it right the first time.
The guy HAD a great reputation,,, and has done several skegs around here.. Keeping my eyes open for a shorty deal. REally kicking myself for not picking up one of the two that went for under 1500 lately.
Shorty for 1500 damn where at lol
Originally Posted by BUP
(Post 4191005)
it is best to have skegs rewelded not from straight cuts but cut outs like shark teeth marks ( VVV ) if you have room below the bullet to make V cuts and weld that up to the matched V cuts in the skeg.. It makes for a lot stronger repair plus easier to make the skeg straight when welding the repair..
VVV VVV Not ______ ______ If I lost anyone I can send pics as to what I'm talking about so you can post them up here. . |
Absolutely. Any butt joint thicker than sheet metal needs a bevel.
I'd be pissd! No heat or penetration. When we welds kegs we also cut a filet in them to fill from inside out. Also I would tell the guy he owes you a prop . I've seen them break and take out prop then take chunk out of cav plate.
Originally Posted by Eliminatorshane
(Post 4191221)
] . I've seen them break and take out prop then take chunk out of cav plate.
I have piks of that.......... lol |
| All times are GMT -5. The time now is 02:13 AM. |
