so this spring deal with this new retainers .What seat pressure are you seeing on the seat?
Originally Posted by Young Performance
(Post 4194792)
The rumor was that Crane got a bad batch of needle bearings. That may or may not be the case. However, I have seen the rockers fail, or start to fail, on 2003 engines and on 2009 engines, and everything in between. There is no way that anyone will make me believe that they used the same batch of bearings for 7 years. Personally, I think it has more to do with the very light seat pressure of the valve springs. I've seen them as low as 100-105 psi on an engine with less than 200 hours. It had only 1 hour above 4000 rpm, so it certainly wasn't abused. Most we see are in the 110 psi range, which still isn't enough. New, they are only about 125 psi, at best.
It baffles me why they use such a short spring with such a low seat pressure. Over the nose pressure is fine at around 400 psi. In order to raise the seat pressure and use any other spring, you have to change the retainers and locks. We have been using a 10* retainer and lock that raises the install height to just over 1.900. The stock PAC springs install at 1.820. There are no other springs out there, that I have found, that will handle that much lift, go in at 1.820, and have enough spring pressure. The only other option is to install longer valves. Obviously, the retainers and locks are much cheaper and should be changed anyway. Eddie So basically what you're saying, is there is more to picking a valvespring than just saying "I want 150psi on the seat". Those rockers prob take a beating off the seat once the spring pressure sags..??....Like bouncing on a pogo stick with a 7ft ceiling? |
I'm beginning to think the valvetrain is the most important part of the engine.
Originally Posted by bblythe
(Post 4194745)
I thought mark told me the port was replaced pwrrda thought it was the starboard
Originally Posted by Cole2534
(Post 4194840)
I will say, I have learned alot about engine builds in the past several years. The most important thing I learned, is assume NOTHING. The average guy, (including myself in the past), would bring a set of cylinder heads in to a machine shop for a rebuild. Never thought about things like, installed height, spring rate, coil bind, valve seat widths, angles, and so on. I'd always leave that up to the machine shop. I also never thought twice about questioning their quality of machine work. Heck, what did I know, Im just a weekend wrench. But as you go, and learn, and you start seeing things like valve stem heights all over the place from inconsistant valve seat grinding, installed heights varying from cylinder to cylinder, incorrect spring selections, shims slapped in place, valve seals getting ripped to pieces from not using spring locators, poor seat/bowl transitions, and so on. You start getting inconsistant chamber sizes, airflow issues, , different rocker geometry from cyl to cyl, all kinds of crap from shoddy head work. When shops let heads go out the door with big variances in seat depths, run. .002, no biggie, .020, that can be an issue. The last shop I used to do my heads, did a decent job on them. They told me all my valve seats were junk, from the previous shop grinding the heck out of the seats. The springs, had been shimmed up, because between the longer valves I had, and excessive seat depth. After installing fresh seats, retainers, my springs came in right where they should have, without shims. Main problem I had with them, was lead time, pricing, and lack of communication. After getting a bill for 2500 dollars to refresh two sets of heads, (didnt include springs), no port work, they tell me, "oh, these heads been milled a bunch in the past, we cc'd them, and they came back at 105cc chambers". Well had I known that, I would have never invested 2500 into them. I found a place locally, that my heads will go to from now on. I've known about him for years, as he has been there since the early 90's. He does cylinder heads, and that is it. He has no intentions on being an engine builder, as he simply says "I stick to heads, its what I do". Its a 1 man operation. The guy's attention to detail, is second to none when it comes to heads. Some of the local fairly big engine shops, outsource their head work to him, even when they have the equipment in house to do it themselves. From head porting,airflow, to the dynamics of valvetrains, he gets it. Lots of engine shops out their, have a guy in the back, who they keep locked up like Sloth from goonies. His job is to work on heads, and gets paid in Baby Ruth bars. No thanks, I'll take the guy who sits at his bench with his vintage high powered spotlight, his reading glasses, and works on heads like hes performing open heart surgery. A guy who is proud to deliver your freshly rebuilt or ported heads, answers the phone, and doesnt take you to the cleaners when its time to square up. Sad thing is, he's a dinosaur and he knows it. With todays cylinder head technology and availabilty, the little mom and pop performance head porting/rebuilding shops, are a dying breed. |
Originally Posted by MILD THUNDER
(Post 4194822)
Eddie, as always that is excellent info.
So basically what you're saying, is there is more to picking a valvespring than just saying "I want 150psi on the seat". Those rockers prob take a beating off the seat once the spring pressure sags..??....Like bouncing on a pogo stick with a 7ft ceiling? Eddie |
Sounds very similar to an under-tensioned head bolt. Insufficient preload to hold things tight and then it gets beaten to pieces.
(Post 4194883)
Thanks buddy. The rockers have to be taking a beating. That's the only reason that I can see why they are failing like they do. I would estimate that at least half of the 525's we get need rocker arms. Recently, we had a 2008 engine with 220 hours that had 13 of the 16 rocker arms that showed signs of a problem. As the needle bearings start to go, the rocker starts moving around and let's the poly lock touch the body of the rocker arm. They are easy to spot. If you see anodizing missing on the inside of the trunnion of the rocker arm, it's on its way out. I've posted some pics of them in the past. I'm in the airport at the moment but I can post some later tonight once I land.
Eddie |
You do not want to get your heads rebuilt in this shop, by a guy who loves his "Rocky Road", a little too much. Reminds me of the "Magic Room" in this video.
https://www.youtube.com/watch?v=dW9liiGyP_g
in my experience with valve size we should be at 150 to 180 lbs at close and 500 at the nose. My background is drag racing.the stack hiegh is a diifer number than I have worked with1.820 /
| All times are GMT -5. The time now is 01:33 AM. |
