-   -   Ideas on a fiberglass hoodscope? (https://www.offshoreonly.com/forums/general-boating-discussion/318595-ideas-fiberglass-hoodscope.html)
1sickvelocity 09-30-2014 06:15 PM
We just built a new Saris 825 and found out we need more air in the hatch, I'm going to go with a hood scoop but just want to know what everyone is using? Or what model or design I should go with . Any input would be great. Thanks
Sick Stinger 09-30-2014 06:27 PM
Harwood internal flange/hidden flange style. Much cleaner look. Get anodized bevel washers with Allen head bolts.
JRider 09-30-2014 09:06 PM
A harwood will need some glass laid inside to make it durable enough for any kind of unexpected load.
Sick Stinger 10-01-2014 06:17 AM
Not sure what Harwood you speak of but the one I bought would hold my father at 250 on it no issue. The one I just bought is crap I layed some heavy matt and resin to strengthen it
Cobra100+ 10-01-2014 10:14 AM
I bought 4 Harwood scoops this year and ALL of them were super thin and had to be reinforced alot. I think they were the 3162 (?) tall aero pro stock models.
phragle 10-01-2014 10:24 AM
Does it suprise you they need to be beefed up? they are made for car hoods, not your drunk azz falling on them........
Tom A. 10-01-2014 11:57 AM
Paging Glass Dave.......
glassdave 10-01-2014 12:20 PM
i have used several Harwood scoops and they all needed to be beefed up. To be fair they are made for cars, i had no probs with any of them.
spectras only 10-01-2014 12:24 PM
With two engines crammed in my small boat, heat was an issue so I built a new hatch with scoops both ends open. It pulls out a lot of heat from the engine bay measured before and after the install. I used a light scoop locally made for drag cars and added more layup to it. Cut the flange off for a lower profile and used a lot of screws to fasten in the hatch.
http://www3.telus.net/spectrasonly/Scoop%20decals
http://www3.telus.net/spectrasonly/Scoop%20project%202
http://www3.telus.net/spectrasonly/mirage257.4.jpg
spectras only 10-01-2014 12:28 PM
There are vent holes behind the panel with Mirage logo on it but it wasn't enough to get air pulled in and out through the aluminum side vents .
