+1 for 1 mile/gallon. If you hammer down a lot, you'll get a little less, and if you're easy on the sticks, you'll get a little better. Twins are worth it though!
i am getting about 1.4 mpg with my 330l with 454 mags.. I dont fill her up, I just keep a 1/4 fuel and add what I think I will burn based on a couple trips.. Ends up at or just above 1/2.
I was hoping for a different thread when I saw the title!
I've tracked nearly all the boats I've had religously on gps. Fill up, reset trip, track miles. These were tracked over entire seasons. I don't lay on the sticks but I do like to run 'em so these numbers reflect a nice broad range of operation. some recent examples
260 Chris Scorp w/twin mild 350's - 1.4 mpg 34 Scarab III w/ stock 454 mags - 1.3 mpg 38 Donzi ZX w/525 SC's - 1.12 mpg moral of the story figure 1 mpg with a little reserve :cool: |
My twin 502mpi's in my 32 AT get better mileage than my single 525SC did in my 28 Pantera.
502mpi's burn about 34gph at WOT. At 3500rpms, they burn about half that. MPG will be determined by boat weight and hull efficiency. |
Originally Posted by 33outlawsst
(Post 4196595)
Remember that's asking price, its the end of the year and they don't want to set on it all winter, if its what they say it is it wont last.
And TWINS in the Midwest are awesome to , go with the biggest boat you can. |
Firing up 2 big blocks at the ramp never seems to get old . That boat is prob going to be the infamous vst set up of 96-97 502's see if the vapor tanks and raw water pumps have been serviced
You will use ALOT of gas the first yr or 2 after that not so bad. Plus- you always have 1 to get home on
Originally Posted by Quinlan
(Post 4196793)
Originally Posted by 2SaltyDogs
(Post 4196521)
OK so this is probably a very cut and dry question but, How much fuel do TWINS (502MAG) actually burn? Now this could be perceived as running wide open and that would be not too long, maybe a day. Basically in a nutshell, I found a smoking deal that is too hard to pass up on a '97 Baja 29 Outlaw with TWINS and low hours from the original owner. The main thing that scares me is the 146 gallon fuel tank and having to fill that sucker up. My boating consists of a few hours of cruising around, a few WOT bursts and the rest of the time, anchored and tied up with friends. This would be my first performance boat and do not want to bite off more than I can chew. I was originally looking at the 25-27' range with a single until I found this Outlaw at a smoking deal ($35k with 240hours in excellent condition). What are your thoughts?
As stated, the 502 EFI burns about 33-35 gph at wide open. They will burn about 18-20 at 3500 rpm. If the boat does 50 mph at 3500 rpm, you are getting 1.25 mpg. So, you could go 50 miles at a 3500 cruise and burn 40 gallons. The amount of WFO blasts will increase the fuel consumption. :D |
| All times are GMT -5. The time now is 04:44 PM. |
