Dry sumping a BBC
I thought of that but, the HTD belts are supposed to be the bees knees, the engine is enclosed and not subject to road debris damaging the system and ensuring good alignment should mitigate belt failure. The belt orientates itself via a "hat" washer on the crank pulley and, if aligned correctly, centers itself on the driven pulley.
But, yeah, it would suck if you lost the belt! Lol
I do have this mercruiser oil cooler. I think it's the hp502 type but I'm not certain. It has 1/2" NPT threads on the oil in and oil out. Would this suffice for flow and cooling capacity?
Pretty sure they make a 1/2"NPT to -12AN fitting.
You will want a thermostatic oil cooler that will handle your HP goal +20% to insure proper oil temps. Never lost a belt and proper tension will keep the belt centered, to tight they walk to the front of driven pulley. You should be able to slid the belt back and forth on the driven pulley with your fingers with moderate force. We run 4 stage pumps up to 600 CU and regulate the vacuum to 6-7 inches. No breathers on the valve covers, vent the system from the tank to your flame arrestor. If you use a vent tank you with always have a oil smell when you come to a stop after a good run.
Good tip.
Thanks for the replies guys.
So, if I use a bypass thermostat on the oil cooler will the cooler I have work with the 1/2" NPT in and out?
Brian, how do you regulate the crankcase vacuum and what size vent hose to the flame arrestor?
Thanks, rob
Thanks, rob
