-   -   Mercury Racing Showcasing Four-Valve Heads on LS Crate Engine at SEMA Show (https://www.offshoreonly.com/forums/general-boating-discussion/319829-mercury-racing-showcasing-four-valve-heads-ls-crate-engine-sema-show.html)
thirdchildhood 11-15-2014 10:01 AM
"Now what I would really like to see is for Merc (or someone else) to develop a similar kit for the BBC!!!!! "
But with enclosed and oiled timing CHAINS! Rubber timing belts are bad news and catastrophic damage waiting to happen on a non freewheeling engine.
mike tkach 11-15-2014 10:15 AM
i believe that is how gm did it on the northstar engines.the 4 valve per cylinder overhead cam design is good but i don,t see it being better than the ls heads at an rpm range that most marine engines will run at.i suspect mercury marine has a plan for these heads and it,s not for a 400 hp boat engine.
SB 11-15-2014 10:43 AM
Valvetrain stability + thus reliability is much better on the pushrod small blocks vs big blocks anyway.
Lighter valves, lighter retainers, lighter valve springs, pushrods not at an odd angle, etc,etc.
hogie roll 11-15-2014 12:54 PM
I just don't see the need. Marinize the ford, Toyota or Nissan OHC v8s if that's what you want.
I recall Porsches DOHC V8 had big bore spacing that could be stroked to 400+ also.
TooLateVTEC 11-15-2014 10:08 PM
Originally Posted by abmotorman (Post 4219433)
Oh boy, someone better tell Edelbrock not to warranty this motor. It makes too much HP?
http://www.jegs.com/p/Edelbrock/Edel...46326/10002/-1
No doubt the exhaust port exiting downward creates some challenges but a thru prop or utilizing the gap between to rear of the engine and the transom would be an option to discharge above the water line.
My main point to this whole discussion is Mercury Racing is recognizing GM's weaknesses and is proactive by reducing valvetrain weight. How many foreign engines still use pushrods? I can't name one! I'm a Blue oval / Bowtie guy but how long to we have to wait for the engineers from GM to design some decent valvetrains?
Thats a built shortblock, not a stock one.
TooLateVTEC 11-15-2014 10:10 PM
That would go over about as good as a screen door on a submarine
Bad Ass TA WS6 11-15-2014 10:13 PM
classic line.
SB 11-16-2014 01:51 AM
Same schit I heard as a Teen Ager 30+yrs ago, and it still goes on today.
Pushrod motors are antiquated. They are near obselence. Blah blah blah blah blah.
Look at what is still kicking serious azz.
Come on people.
Go drive a new Vette and you'll wanna go home and sleep all cuddled up with your pushrods.
phragle 11-16-2014 12:35 PM
Chrysler is setting the bar with 700+ hp off the showroom floor. Expect gm and ford to be working on comparable numbers, lest they want to sit back with egg on their face.
Pliant 11-16-2014 12:39 PM
[QUOTE=VortechSS;4214304]I've spent a ton of time in the past couple months trying to figure out how to make this work.... I'm a HUGE GM guy and play with LS junk every day but it's hard to look past the HP/CID of the new Coyote 5.0s. They are mean for their size. Take that math and apply it to 400+ cube builds then add more efficiency with bigger cams and we're looking at 650
http://www.digitaltrends.com/cars/20...stang-engines/
The power of Voodoo?
Don’t get too used to the snarling Coyote, though, because it may not be around for too long. The upcoming 2016 Mach 1 is rumored to have an all new V8 known as ‘Voodoo’. In the Mach 1, with the help of forced induction, this engine might put out as much as 650 horsepower.
Coming to a theatre near you..Sooner than you might think.
flat rate 11-16-2014 12:42 PM
the guys at Mercury told us at sema that they designed the heads with boosted application in mind. They flow well over 400 before any massaging. After going to drag week this year and seeing that the majority of the cars were running twin turbo ls engines. They said they will be available late next year and complete kit will be $8000.00.
flat rate 11-16-2014 12:48 PM
Dohc head pics
4 Attachment(s)
[ATTACH=CONFIG]532698[/ATTACH][ATTACH=CONFIG]532699[/ATTACH][ATTACH=CONFIG]532700[/ATTACH][ATTACH=CONFIG]532701[/ATTACH]
Keith Atlanta 11-16-2014 12:59 PM
The article is confusing. Somebody explain to me how a 180 degree engine is a "V8". Isnt it a "Flat" 8 or a "Horizontally opposed" 8.
Am I the idiot or was the author who wrote it an idiot? I am confused... Nothing related to a "V" is flat and vice versa. I am sitting here scratching my head trying to figure out what the heck they are talking about.
Pliant 11-16-2014 02:06 PM
http://blog.americanmuscle.com/horse...ne/#more-13230
Keith Atlanta 11-16-2014 03:43 PM
Originally Posted by Pliant (Post 4220185)
Ahhhh.... The block is a V and the crank is flat.
SB 11-16-2014 03:59 PM
Complete ?
What about pistons, intake, exhaust, and other stuff ?
wannabe 11-16-2014 03:59 PM
Depending on how they designed the port shape they may not see much gain. Why??? The LS cylinder head with the cathedral port was designed with a maximum amount of "swirl" and "tumble" in it.... shhh its a secret...
Thats why you see twin turbo LSX eninges making 2000+ HP reliably.
Wannabe
