Prop help...
Old 12-17-2014 | 01:01 PM
Originally Posted by Knot 4 Me
Spin whatever direction Danny Sullivan did. Worked out well for him.
Denny Crane (representing Dr. Loof Lipra) advised me to have another rum drink. Alan and I are going to test that theroy .
phragle is offline
Old 12-17-2014 | 01:29 PM
Originally Posted by On Time
Doesn't it depend on if you're a right or left handed person?
Close but no cigar. It depends on which hemisphere you are in. You can determine this by flushing your toilet and seeing which way the water rotates.
bulletbob is offline
Old 12-17-2014 | 01:38 PM
The question is best answered by paying close attention to the tide charts and changing props accordingly.
snowhammer is offline
Old 12-17-2014 | 07:48 PM
Isnt it more whether coming or going??? You cant have "Red Right Return" Going !!!! Duh also, If youre trimmed up and Haulin azz if you let go of the steering wheel which way does it turn??? Have you even tested that yet????
fastdonzi is offline
Old 12-18-2014 | 06:44 AM
Swap to a bravo 3. Problem solved.
ham_r_down01 is offline
Old 12-18-2014 | 09:01 AM
In and out at the same time? Isn't that like crossing the streams? If you do go that route, just make sure you never take it over 88 mph.
Quick2500 is offline
Old 12-18-2014 | 12:09 PM
On Time's Avatar
In algebra, the angle of the dangle (x) is necessary to find (y), the heat of the meat, provided that the maxis of the axis (y=mx+b) and the gravity(grab-ity) of the cavity remains constant. This is how you determine pitch and rotation.
On Time is offline
Old 12-18-2014 | 12:18 PM
I was under the impression that dangle (x) and heat (y) were directly proportional and both affected as such by the cavity in question.
Old 12-18-2014 | 12:20 PM
On Time's Avatar
Yes they are, and proportional to pitch and rotation needs. All this is theoretical, however, and the best results are still determined by an old fashioned "trial run".
On Time is offline
Old 12-18-2014 | 12:21 PM
SB
I slept with a Dangle (last name) who apparently knew the heat of the meat but miscalculated gravity on the placement of her cavity and we got hurt...a little.
SB is offline
