Volvo power/drive?
My Blackhawk required the props be "timed" as well. I assumed it was to make sure the props are entering and exiting the water at the appropriate time, since it can vary depending on how the two props are spaced.
I wrote a story last year and mentioned how that many call it an anti cavitation plate so I had to straighten that issue out. Jeepers if I had an extra 10 bucks for every Volvo that I worked on - I would be rich. Just caught up with Volvo a couple of months ago for all the very lastest and training. Direct fuel injection and all LS engine based engines is on its way from them.
I had a Volvo SX drive and loved it. Shifted like butter and no issues. A buddy had the same boat with a DP drive and he beat the snot out of that thing on Lake Michigan for 5 or 6 years. Never had a single issue. I am certain he would have went through 3 or 4 Bravos!
Merc bravo III is good but the Volvo DP is by far better especially the newer style 2007 to current. they are faster by 1.5 to 2 mph- hydro dynamically than the 2006 Volvo DP back version and so is the SX outdrive. Model year 2007 was a design change and complete make over. Like I said in the posts before here, the Bravo III has some problems even with the newer style propshaft seal & SB that came out about 3 or 4 years ago.
If you want I can send you pics of what in the world I am talking about clocking / timing the props and you can post them up here. I can add to the reasons why after the pics posted.
Yes the Blackhawk drives in the service manuals use to show how to clock / time the props for the proper installation. Also years back so did some of the very early Bravo III service / tech info.
