Has Anyone Air Bench Tested the CFM Dana EX2000 Flow Torque Exh Manifold re Merc 496?
What part of the riser failed? Saltwater use? I'm strictly freshwater and plan to drain after use. I also plan to make mine dry to the tips. Looking up old threads by Raylar saying up to 25 hp vs mixing water in the stock riser location. I am still running stock manifolds on mine w/ turbulators removed. I also welded stainless extensions onto the stock risers. The water now mixes 1" before the tips.
Leak Test Procedure for Dana EX2000 Manifold?
Do you know exactly what procedure method he actually used to successfully leak test the Dana manifold to confirm the leak? If yes please post.
we used a couple different air expandable pipe sealers,,he's in the well business.also made a bottom block off plate.then seal it up so you can pump water in and look up from the manifold side.his was leaking like a mofo.
Back to my original question. Has Anyone Air Bench Tested the CFM flow of the Dana EX2000 Flow Torque Exhaust Manifold made for the Merc 496? I am looking for those CFM numbers.
