Aluminum diamond plate ?
I removed mine from my Velocity and replaced it with new. Cost about $125 for a 4x8 sheet. If it has any pitting, polishing will only enhance the pits (they will stick out like a sore thumb). Mine was pitted. And to be honest, it was easier to just replace than it would have been to get in there and polish anyway.
I have used many aluminum polishes. Currently I have been using White Diamond and I think it's pretty good. I hand rub mine and it is pretty tough at first. If you do it often it's not to bad. If you used a polisher it would be somewhat quicker, but with all the extra clean up I find it is just easier to get a beer and start rubbing. If it is real dirty, try using a small piece of carpet as your rag. Then use a finer cloth once the oxidation is gone.
Ha ha....Only a couple. It really isn't too hard if you keep up with it, and do a little section at a time. Much easier with the engine out, but then you need a couple more beers to clean and paint the bilge. And a few more to put it all back together.. lol Then its on to polish the Imco lower and aluminum trailer. Got to go, the beer truck is here.
