Alternator Amp requirements and other electrical issue questions >
Old 01-29-2015 | 04:26 PM
Originally Posted by cdaniel525
OK... ill do my best with all the checking of connections... if I still have any issues, I may try a re-wire... What would you suggest in all that?? Get a new harness from the round engine connector to the helm, and from there re-wire everything?
Just run a tinned heavy cable at least 6 ga. Black and red to distribution panel from battery switch, abandon wires in harness for main power.Include a fuse/breaker always. Starter wires need to be heavier than 6 ga.
MichiMike is offline
Old 01-29-2015 | 04:46 PM
Originally Posted by onesickpantera
FYI, myself and several friends have had good luck with this model:
http://www.dbelectrical.com/p-3609-n...e-adr0334.aspx
Is the delco style the correct one for Gen IV??
Thats kinda what I did but individual wires to the key and radio... Ill look into doing that to the distribution panel as you suggested with a larger wire. Should be easy enough to do as the battery switch isnt far from there.
cdaniel525 is offline
