SSM #6 Instillation Drawing >
Old 02-18-2015 | 02:23 PM
Default SSM #6 Instillation Drawing
Anyone got a CAD file or drawing showing the mounting holes and cut-outs for A SSM#6.
999JAY is offline
Old 03-25-2015 | 02:01 PM
In desperate need of this can anyone help? even a photo of a mounting diagram will do.
999JAY is offline
Old 03-25-2015 | 02:30 PM
cougarman's Avatar
What ya need, if it's just a drill Print Mercury can mail ya one.
Or do you have additional plans in mind?
Jon
Attached Thumbnails SSM #6 Instillation Drawing-6_drive_dimensions.jpg   SSM #6 Instillation Drawing-6_drive_x_dimensions.jpg
cougarman is offline
Old 03-25-2015 | 03:51 PM
Drill print would be ideal, I looked Mercury site for a contact email but couldn't find a direct email address.
I am swapping the #6 for Arnesons and need to mock up the transom as it is at present to cross reference all the dimensions.
999JAY is offline
Old 03-25-2015 | 05:59 PM
cougarman's Avatar
I can probably get you the drill pattern, however I do not have the center point of the drive shaft in this cad model.
Also what format-(s) of cad can you work with?
Jon
Old 03-25-2015 | 06:25 PM
cougarman's Avatar
I have the drill pattern on cad, let me know what format you can work with
Old 03-26-2015 | 09:19 AM
That would be ideal Cad 2011,DXF,DWG or PDF should all work.
Thanks for you help its much appreciated, email to [email protected]
999JAY is offline
Old 03-26-2015 | 01:09 PM
cougarman's Avatar
Sent igs and stp ...not a fan of dfx or dwg.
I work in Unigraphics... Solids base software.
I can export other formats if this fails.
Igs should we work for a few curves
And points
Jon
Old 03-26-2015 | 03:21 PM
Cheers Jon I will give it ago in the morning.
999JAY is offline
